Author Topic: Pressure plate help needed  (Read 333 times)
AlanCasida
« on: November 10, 2026, 07:35:04 PM »
two steps forward and one step back on project 416. I got a call from my machinist today and when balancing my rotating assembly they found that my pressure plate would not bolt up to my OEM 428 flywheel. George likes to check those when balancing a rotating assembly. I did a little research and found that 428s used a larger clutch plate(11.5" I think) and the pp I sent him was for an 11" clutch. So, I am needing a Long style pp that will bolt up to my OEM 428 flywheel and still clear the standard truck bellhousing. I tried a diaphragm style pp but it hits the bellhousing. I have a complete 428CJ motor and spare OEM 428 flywheel on a cart that I mocked it up on. So, I am hoping someone might know or have a good part number of a PP that will work in my application. Thanks!
galaxiex
Re: Pressure plate help needed
« Reply #1 on: November 10, 2026, 08:07:29 PM »
Sorry, I don't have a part #.
In the mid 80's I used a Hays 40lb steel flywheel  on my 390 with a Re manufactured 11.5" Long style PP and clutch kit.
Back then Re-Man stuff was still good quality.
I used a Truck bell and it fit fine.
The Hays flywheel was drilled for both patterns, 11 and 11.5.
The Re-Man clutch kit I got "might have been" an OEM unit for all I know.
I do remember the PP had "LONG" stamped on it.
I also remember I ordered the clutch kit for a truck application, don't remember which one tho....
It was almost too much clutch for a relatively light 68 Mustang street car.
Never gave me a lick of trouble in many miles of not so gentle use.
« Reply #2 on: November 11, 2026, 05:40:08 AM »
The 11.5" pressure plates use a 12" disc, so you will most likely need a new disc as well.  The only pressure plate I know that still has an 11.5"/12" bolt pattern is the McLeod diaphragm pressure plate for 12" discs.
I honestly think you'd be better off just buying a new flywheel.  You just don't see a lot of 11.5"/12" Long stuff anymore on the major brands.  A new flywheel will have multiple patterns on it and it won't be susceptible to cracks like the factory cast iron flywheels.
« Reply #3 on: November 11, 2026, 09:13:57 AM »
+1 on the new flywheel.  After you've seen the results of one stock flywheel explosion, you will never run one again.
The Real McCoy
« Reply #4 on: November 11, 2026, 09:16:47 AM »
About 9 years ago I was doing a TKO 600 conversion on my 428 Stroker.  The kit from American Power Train included the flywheel, clutch disc and diaphragm pressure plate. I was using the C5TA? truck bell housing and I don’t remember the clutch diameter. I run into the same problem of the pressure plate contacting the bellhousing, if my memory is correct it was at about the 10:00 position, road side of the engine. It was not possible to install the clutch with the bellhousing in place so I removed the bellhousing to install the clutch. Well, upon rotating the engine,  part of the pressure plate still contacted the bellhousing, just barely.  I pulled the bellhousing and ground a little relief at contact point to resolve,it really didn’t take much. It’s been working fine going on9 years.  The down side is any clutch work means the bellhousing will have to come off.
63 1/2 Galaxie 500
428 CJ Stroker with 427 2x4 Intake, 427 Long Exhaust Manifolds, Quick Fuel Carbs and TKO 600.
"What gets us into trouble is not what we don't know, it’s what we know for sure that just ain’t so."                            Mark Twain
AlanCasida
« Reply #5 on: November 11, 2026, 10:04:30 AM »
Thanks for the info, guys. I have a Hays 12-345 flywheel that I think will work. When I took my stuff to the machinist I didn't even think about the 428s having a different pressure plate. I double checked it this morning and I think it has the right pattern for the 11" Long style pp. An added plus is I get to use up some of my stuff that's just laying around.  ;)
