Author Topic: "UN"Polishing Aluminum  (Read 460 times)
JacksFordParts
« on: November 10, 2026, 12:35:48 AM »
Does anyone have any direct experience. hopefully a successful one, with dulling the finish on polished aluminum?  I have quite a few parts that have been polished and I would really like to go back to a raw looking finish.  2 blowers, a set of aluminum TP heads, intakes and a couple SOHC timing covers.
I know painting will be the easiest process but was wondering if anyone had any tricks up their sleeves...?
mygasser
Re: "UN"Polishing Aluminum
« Reply #1 on: November 10, 2026, 08:23:28 AM »
media blasting works and gives the 'as cast' look.
neil.
kcoffield
    • inlinecarb.com
« Reply #2 on: November 10, 2026, 09:47:05 AM »
I have weld repaired and cast many custom intake manifolds from scratch and have lots of experience trying to blend and match repairs on those and carburetors too. You can get a range of color change including that which closely resembles as cast color but you'll find it's very difficult/never get the true as cast appearance back after polish. The color can range from very dull grey to bright aluminum depending upon the media. I never blast any surface exposed to the engine.
On small repairs I use the surface of a file and light hammer blows to stipple/texture the repaired area making it much more similar to that of the original cast surface, then media blast the entire intake to give it uniform color. It's tedious and would be totally impractical for an entire intake or blower. I've often thought that some crazy course media might come close but never been motivated enough to try to source such media or mod the blast gun to accommodate it.
The other thing to be aware of, the color will change over time as the blasted surface oxidizes. Finer medias usually age to be more grey and resemble the (clear) anodized color of commercial intakes. Often, a weld repaired area wont age color the same even though initially undetectable, but in most cases it's a very subtle difference. There are ways to make this coloring aging occur more quickly without actually anodizing.
Experienced and trained eyes will notice these things immediately, but once in an engine compartment.....lesser so. Knowing your business Jack, and given the effort/cost it takes to polish a blower or intake, I'd save those parts for those that want a polished part.
Best,
Klely
« Last Edit: November 10, 2026, 09:50:12 AM by kcoffield »
« Reply #3 on: November 10, 2026, 10:30:22 AM »
I use Black Beauty(Black Diamond) media material in my sand blaster with different pressures for different textures.   You can buy it from Northern Tools in a 50# bag. I use it for removing smooth surface or paint on aluminum intake manifolds.  Of course it requires pressure washing with high pressure afterwards to remove any broken shards of material left behind.  I do not use glass beads on anything going into or on an engine since they crush and imbed into the aluminum or iron.  Steel shot abrading also leaves shot materials in tiny spaces, so I don't like to use that on internal engine parts.  Sand blasting texture depends on the grit size you use, but it breaks up like glass and can embed in the aluminum but leaves a smoother finish.  Joe-JDC
« Last Edit: November 12, 2026, 09:07:02 PM by Joe-JDC »
preaction
« Reply #4 on: November 10, 2026, 04:41:17 PM »
 I have had good experiences with using a vibratory tumbler using 3/16 x 5/8 angled ceramic media with a soap compound and also water depending on the desired finish.
allrightmike
« Reply #5 on: November 12, 2026, 05:50:02 PM »
A few years I acquired a "68 Triumph Bonneville that had polished case halves. These are sand cast parts, and so have quite a grainy surface finish. I used a compressed air descaler made for removing welding flux. I rounded the pins to a spherical shape and went to work. The result looked exactly like a sand cast part. Experiment with air pressure and technique.
'60 Starliner 427 4speed.
Chrisss31
« Reply #6 on: November 12, 2026, 09:55:39 PM »
You could try a muriatic acid wash.  It dulls the polish on aluminum truck parts pretty quickly.
70tp
« Reply #7 on: November 15, 2026, 10:48:57 AM »
From my experience, don’t use muriatic acid on cast aluminum…. It’s porous and soaks it up and won’t ever stop eating
