Author Topic: Does having a machined combustion chamber affect detonation?  (Read 582 times)
Fordman
« on: November 07, 2026, 02:00:55 PM »
Just a thought, how does a machined combustion chamber(factory EDC/MR427) affect detonation VS an as cast chamber?. Any real world experience on this?. Thanks....JJ
hbstang
Re: Does having a machined combustion chamber affect detonation?
« Reply #1 on: November 08, 2026, 01:44:17 PM »
i think the shape of combustion chamber is a bigger factor than surface texture or finish.also cam has a big impact on that,and many other factors.
FrozenMerc
« Reply #2 on: November 10, 2026, 12:28:38 PM »
As HB noted, there are many factors, but if the surface finish contains little peaks or nubs that heat up and act as glow plugs, you can get a detonation problem, even in very low compression (think flatheads) applications.
« Reply #3 on: November 10, 2026, 12:58:04 PM »
On a machined combustion chamber, you need to chamfer the sharp edges, including the spark plug area. Here is a before and after on my EDC heads.
The machined chamber will also give you less variation in size.
Also, on the EDC chamber, you'll need a Steel shim or Fel-Pro 8554 shaped head gasket because some of the others won't clear the corners of EDC chamber.
Fordman
« Reply #4 on: November 10, 2026, 07:28:10 PM »
Thanks for the replies,  according to google(why asked here for hands on experience) says that a machined combustion chamber "drastically reduces" detonation. Thank you gentlemen!!.....JJ
