Author Topic: ARP Rocker Shaft Studs - finger tight or torque?  (Read 335 times)
fairlaniac
« on: November 05, 2026, 08:18:33 AM »
Just curious, I've always finger tightened them without any reason why? Is there a proper way? Just doing some valvetrain work and just got to thinking about it.
Thanks,
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
machyoung
Re: ARP Rocker Shaft Studs - finger tight or torque?
« Reply #1 on: November 05, 2026, 09:14:58 AM »
Doug's (POP) instructions say to use Loc-tite but does not state torque...
« Reply #2 on: November 05, 2026, 09:27:10 AM »
Just to be a devil's advocate...
I've never torqued and I've never threadlocked.  Finger-threaded them in, backed it up a hair, and then torqued the nut down.
mike7570
« Reply #3 on: November 05, 2026, 10:59:08 AM »
Same, finger tight no loctite, nuts to spec. T&D  street version Edlebrock aluminum heads 7,300rpm no problems with bolts or valve lash. 🤞
Phil Brown
« Reply #4 on: November 05, 2026, 11:57:12 AM »
To get a stud to torque your doing one of two things, running out of threads on the stud and jamming it up (possibly damaging the part with female thread) or
Your bottoming the stud in the threaded hole also risking damaging the part.
Always only finger tight
A friend has a side oiler block that he torqued the head studs in years ago......cracks everywhere in the deck, really sad because it was a really nice block  :(
« Reply #5 on: November 05, 2026, 01:05:16 PM »
Technically, studs are not supposed to bottom out.
There are studs made for some applications that have balls on the end so that can't occur.
