If all you'll be using it for is the 2500 RPM break-in, you'll probably be okay. The factory progressive linkage only uses the main carbs primaries for idling and lower RPMs with no load. You should be able to get the desired RPM with just that initial step on the linkage, under no load, which means one carb should work. I would NOT try upping the RPM beyond break-in with just one carb. It would likely end up being very lean on several cylinders, which means lots of heat in those cylinders. Under no circumstances should it be driven that way.
