Author Topic: FE Deck Plate  (Read 179 times)
FirstEliminator
FE Deck Plate
« on: October 13, 2026, 08:38:43 AM »
BHJ makes two deck plates for the FE. One for up to 428 bore and the other is for 427. I have the smaller bore size plate. Is there any reason why the smaller plate cannot be bored to accommodate a 427?
thanks,
  Mark
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
Re: FE Deck Plate
« Reply #1 on: October 13, 2026, 10:33:27 AM »
Yes you can, we did my first one that way, use it all the time on big bore stuff up through 4.375
Then I ended up buying one for the 427-ish bores and one for the small bores.
BTW, they work great for pressure testing too
pbf777
Re: FE Deck Plate
« Reply #2 on: October 13, 2026, 11:20:06 AM »
     I believe "BHJ" is no more.
     Scott.
Re: FE Deck Plate
« Reply #3 on: October 13, 2026, 11:49:41 AM »
There are other deck plate companies, plus my local buddy can knock them out quick on the Centroid, especially if someone wants "Bullock's Power Service" ground into the edge. I'll get a rush order done for those :)
FirstEliminator
Re: FE Deck Plate
« Reply #4 on: October 13, 2026, 01:09:51 PM »
Thanks Ross, after boring the deck plate, were there any problems using it on the smaller cylinder bores?
Mark
Mark
68 Monterey 390 C-6
Re: FE Deck Plate
« Reply #5 on: October 13, 2026, 03:01:30 PM »
Mark, I bored mine from 4.23 to 4.375, so I felt I was getting close to the edge with smaller gaskets.  I like to make sure I clearly cover the fire ring of the gasket when compressed, but as long as you are small enough to do that it shouldn't matter.
I ended up with 2 more over time, but I could have likely got by with one more.  I have 2 sitting in the hone rack, and usually use the last one as a pressure tester
