Author Topic: Anybody offering CNC porting of 427 SOHC heads?  (Read 1067 times)
Wade427
« on: October 05, 2026, 04:01:11 PM »
I have a set of the COON heads.  Was wondering if anyones offers CNC porting.
Thanks,
Wade
hbstang
Re: Anybody offering CNC porting of 427 SOHC heads?
« Reply #1 on: October 05, 2026, 06:02:10 PM »
ponds heads are cnc ported,but i never heard of anyone else doing cnc porting on sohc heads,coon heads,dove heads,munro heads,are all differant enough that you could not use one program on another.someone onhere may be able to recomend and hand porter to do it for you.just my .02
428kidd
« Reply #2 on: October 06, 2026, 07:17:35 AM »
If i remember the Coon D port heads at one time where the best flowing cammer heads out there?
Wade427
« Reply #3 on: October 06, 2026, 11:32:01 AM »
Keith Craft used to offer it a few years back.  Just wondering if anyone took it over.
Autoholic
« Reply #4 on: November 11, 2026, 11:43:44 PM »
You might try Kirkham Motorsports. They have done a decent number of SOHC powered Cobras. I just don't know how much machining they did on the engines. The SOHC is not a common build though and it poses unique risks to a machine shop due to how expensive the heads are. You're likely better off hiring someone to do it by hand unless you want to pay a lot for CNC work.
~Joe
« Reply #5 on: November 12, 2026, 11:09:50 AM »
I don't recall Kirkham building their own engines.  IIRC, Keith Craft built all of their engines back in the day.
Autoholic
« Reply #6 on: November 12, 2026, 12:43:42 PM »
They don't normally build engines but they have done lots of CNC work on engine parts and I think they even did a billet aluminum FE engine block. I also know they have had bad experiences with engine shops. I want to say there was a story about an SOHC that wound up with sand in the engine because of a shop that was used? If Keith Craft no longer works on SOHCs, then you have to look at any company that has experience working with these engines. Robert Pond Motorsports might have done CNC work. Ed Pink Racing Engines might have done CNC work on heads because they have done cammers too. Not sure how much engine building Holman Moody still does. But for a Cammer, you're going to be stuck either looking at companies that have worked on these engines in the past or you need to find a good porter to do it by hand.
I wouldn't take a pair of SOHC heads to a shop for CNC porting if they haven't worked with these engines before. And even if a shop has experience with these engines, did they bother to CNC port the heads? Realistically, you're not going to gain a whole lot in performance from a CNC porting job over a quality job done by hand to port and polish a head, but the cost in CNC work could be way higher. For a one off job, where do you spend your money? CNC work starts to make sense when you are going to do a small batch of heads. I'm assuming that Keith Craft was already contacted and they turned down the job?
« Last Edit: November 12, 2026, 12:56:00 PM by Autoholic »
~Joe
« Reply #7 on: November 12, 2026, 01:20:30 PM »
They are good at making things out of metal, but as far as engine building goes, I don't think Kirkham is there.
They may have a 3-axis CNC, but there again, you have to have a good port that's been massaged by hand in order to digitize it and copy it.
For SOHC stuff, a good hand-porter would be where I'd head.
BTW, Keith Craft has been out of business for quite a few years now.
« Last Edit: November 12, 2026, 01:27:31 PM by blykins »
MRHP
« Reply #8 on: November 20, 2026, 03:04:38 PM »
If I owned a Cammer I'd be looking at hand porting from a very reputable engine builder such as Kaase, Blair Patrick, Chad Speir, Darren Morgan, Lykins, etc. A CNC port is only as good as the first hand ported runner.
