Author Topic: 10 - 428 Blocks for sale  (Read 599 times)
JacksFordParts
« on: September 24, 2026, 08:05:15 PM »
#8 - 428 - A Scratch 4.190 Block 6L1 Date - This was a running engine I took in trade - I disassembled for inspection - the bores are nice and clean with no ring lip at the top - $850
#10 - 428 - A Scratch 4.185 Block Fresh Bore - 6E13 Date - With new Speedpro L2303NF Forged coated 4.190" pistons and pins - Bores coated with grease - $1250
#11 - 428 - 1974 Service Block STD, Needs 1 Sleeve 4E13 - Core engine that needs a sleeve and machined - $1750
#13 - 428 - A-Scratch .030 Fresh Bores - 5L6 date - Partially filled about halfway up the cylinders  (Nice Block) - $1450
#14 - 428 - A-Scratch .030 5M18 date - 1 Sleeve - Bores Decent, Has been Run - No ring lip - Sleeve Stepped and done correctly - $1600
#17 - 428 - A-Scratch STD. 5L10 dated - Timing Cover Face Pitted & Main caps are pitted a bit as well - Bores look good - Will need full machining treatment - $1750
#19 - 428 - A-Scratch .030 5L20 dated - Clean Bores - $1500
#21 - 428 - A-Scratch 4.140 .010 5L18 dated - has surface rust from sitting around - $1800
#24 - 428 - C-Scratch .030 1K4 date - Has a stuck piston and needs 1 Sleeve - $1250
#25 - 428 - A-Scratch STD - 5L20 dated - Nice block - $2000
Package deal for all or multiple blocks readily available
I will sonic test any of the more expensive blocks if buyer wants it done.
All blocks are located in Carson City, NV
I ship almost anywhere, including internationally and I get very good rates for LTL freight
Jack Tindle
Jacks Ford Parts
775-315-8801
