Author Topic: Bullock's Power Service - 511 FE - 710 HP 741 TQ  (Read 1709 times)
« on: September 04, 2026, 06:51:28 PM »
Engine use - Mercury Park Lane - mean street machine
Dyno run -  https://youtube.com/shorts/Nk9XnmQXOHI
Performance Summary:
      Cubic Inches:  511             Dyno brand: Stuska
      Power Adder:  N/A             Where dynoed:  Dale Meers Racing, Buffalo, KY
      Peak Horsepower:  710 @ 5850
      Peak Torque:  740 @ 4600
Engine Specifications:
   Block brand, material, finished bore size, other notes: BBM iron, 4.375, CnC squared, aligned, torque plate honed
   Crankshaft brand, cast or forged, stroke, journal size: SCAT forged steel 4.25, internally balanced
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Molnar 6.70
   Piston brand, material (cast, hypereutectic or forged), dish/dome volume, static CR: Racetec 2618, 11.78:1, 17.5cc
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Clevite rod and main bearings, Durabond cam bearings
   Piston rings brand, size, other notes: Mahle 1.5/1.5/3.0
   Oil Pump, pickup, and drive:  Melling M57HV, Milodon pickup, ARP drive
   Oil pan, windage tray, oil filter adapter:  Milodon deep sump, no tray, Ford oil filter adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Bullock's Power hydraulic roller, 247@.050 intake, 114 LSA
   Lifters brand, type:  Morel standard travel
   Timing chain and timing cover: Cloyes 9-position roller, Ford early 427 timing cover, Lykins pointer
   Cylinder heads brand, material, port and chamber information:  Ported Trick Flow aluminum, Manley Viton seals
   Valve springs: PAC Trick Flow 1.55, 170 seat
   Rocker arm brand, type (adjustable or non-adj), material, ratio: Lykins non-adjustable 1.76,
   Rocker shafts and stands, brand, material: PoP stands and HS shafts
   Pushrods brand, type, length:  Custom Smith Brothers 5/16, .116 wall, oiling
   Valve covers, brand, type:   Mercury chrome pentroof
   Distributor brand, advance curve information:  Dyno'd with MSD, but swapped to Unilite, 36 total
   Harmonic balancer brand:  Powerbond
   Water pump brand, type (mechanical or electric):   Iron, powered by electric on dyno
   Intake manifold brand, material, porting information:  Port matched Victor EFI
   Carburetor(s) brand, type: Holley 950 HP
   Exhaust manifolds or headers brand, type:  Dyno headers
« Last Edit: September 06, 2026, 08:17:23 AM by My427stang »
Stangman1
Re: Bullock's Power Service - 511 FE - 710 HP 741 TQ
« Reply #1 on: September 04, 2026, 10:20:40 PM »
Nice Ross love the torque. If I’m reading it right not a very big cam for a 511. 5900 RPM should be pretty indestructable
chilly460
« Reply #2 on: September 04, 2026, 11:08:17 PM »
Holy hell, that’s a great build.  As stated, it’s not turning much rpm!!!  Torque is impressive, this thing runs with good 460 strokers with similar specs. TFS are great, obviously, but the ported ones really seem to take advantage of the cleaned up flow past the stockers stall point.
What year Merc?  Imagine some type of scoop is needed for the Victor…
« Last Edit: September 04, 2026, 11:12:01 PM by chilly460 »
« Reply #3 on: September 06, 2026, 08:19:30 AM »
Video link added above
It's a 1964 Park Lane, really neat car.  Game plan is a T-bolt style hat with hoses to the high beams.  This one isn't running any spacers, but yes, that Victor is tall.  Luckily the car isn't ready for paint yet :)
chilly460
« Reply #4 on: September 06, 2026, 09:28:31 AM »
Obviously I have a soft spot for the 63/64 Marauders, sounds like he’s building a mean one.
« Reply #5 on: September 14, 2026, 06:38:35 PM »
Having issues adding files, will be back to try again :)
« Last Edit: September 14, 2026, 06:40:56 PM by My427stang »
