Author Topic: Hurst shifter boot compatability 1966 Cyclone  (Read 1148 times)
c9zx
« on: August 15, 2026, 03:24:49 PM »
Car is 1966 Cyclone, shifter is Hurst comp plus. I now have the correct tunnel hump from Auto Metal Direct. Will the Hurst shifter boot be to long and wide to work with the factory console shifter bezel opening, or is the opening too small? If the opening is too small, can it be trimmed to fit without looking hacked up? All responses will be appreciated. Thanks, Chuck
1969 Eliminator G code
CSX-7031 FIA Cobra
2007 Mustang GT, Whipple
1966 Cyclone GT
6667fan
  • Every Second Counts
Re: Hurst shifter boot compatability 1966 Cyclone
« Reply #1 on: August 15, 2026, 05:59:23 PM »
If you are not a FCA member it would be a good move to join.
A search of the 66-67 group’s technical section might provide your answer.
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
Ctcobra
« Reply #2 on: August 28, 2026, 02:59:57 PM »
Chuck, I used this boot and trim in my 66 Comet build. It fits perfectly and looks correct. https://www.ebay.com/itm/262769474897
« Last Edit: August 28, 2026, 03:05:12 PM by Ctcobra »
3goats
« Reply #3 on: September 10, 2026, 08:43:12 AM »
I used this boot that fit in my console with a hurst shifter..   https://www.amazon.com/dp/B0003NWKDY?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_3
« Last Edit: September 20, 2026, 10:40:00 AM by 3goats »
