FE Technical Forum
Fuse size
Topic: Fuse size (Read 949 times)
Colorado75F100
Newbie
Fuse size
July 29, 2026, 12:47:48 PM »
Hi guys, so I have now order two different size glass fuses and none of them fit. They're 1 &1/8 long. Its on my 75 F100. Recommendations guys?
Thanks,
Dan
mygasser
Full Member
Re: Fuse size
Reply #1 on:
July 30, 2026, 08:59:54 AM »
are the ones you bought too long? if so as a temporary fix to get you going i've carefully 'crunched' the glass tube with cutters and pushed the ends together to fit the holder. it'll give you back the safe/fused use of the truck until you source the correct ones.
neil.
FrozenMerc
Full Member
Re: Fuse size
Reply #2 on:
July 30, 2026, 12:19:23 PM »
What is the diameter? If it is 6 mm, or just under a 1/4", you probably have AGC type fuses.
Should be able to get them anywhere. 200 pc assortments on Amazon for $12 or so.
FE Technical Forum
Fuse size
