FE Technical Forum
TFS Heads Rocker Shaft Oil Feed.
Topic: TFS Heads Rocker Shaft Oil Feed. (Read 523 times)
petew
Newbie
July 17, 2026, 11:56:23 AM »
The oil feeds in my TFS heads that supply the rocker shafts measure about .171 . Is there any need to restrict them further or can they be left as is ?
Re: TFS Heads Rocker Shaft Oil Feed.
Reply #1 on:
July 17, 2026, 11:59:44 AM »
Restrict them if you're oiling through the heads.
The hole is appropriately sized for a 12-24 tap. Run a tap down the hole about 1/2" or so, then get yourself some short set screws, drill an .080" hole in them and screw them in.
YouTube: Lykins Motorsports
petew
Newbie
Reply #2 on:
July 17, 2026, 12:34:09 PM »
Again , thank you
FE Technical Forum
