Author Topic: Camshaft Bolt  (Read 551 times)
petew
Camshaft Bolt
« on: July 05, 2026, 11:45:38 AM »
Went to put the cam gear on my Comp hydraulic roller cam so I can degree it and found that the thread in the camshaft is 7/16 -20 not the standard 7/16 -14 .
So is there a specific ARP bolt that will work for this or is a grade 8 bolt sufficient ?
Re: Camshaft Bolt
« Reply #1 on: July 05, 2026, 12:23:32 PM »
I doesn't even have to be a grade 8 bolt. A grade 5 will work just fine, especially with the extra clamping force of the 20 pitch thread.
Re: Camshaft Bolt
« Reply #2 on: July 05, 2026, 01:04:56 PM »
Take a measurement of the length that you need.  Depending on your setup, it may be 1.5" UHL or 1.750".  Will depend on if you have a pump eccentric, thick washer, etc.
Yes, ARP has 7/16-20 bolts in either length.  With a steel core roller cam, I like to torque them at 65-70 lb-ft.
