Author Topic: sohc timing cover gaskets  (Read 486 times)
hbstang
« on: July 02, 2026, 02:57:28 PM »
does anyone have a picture of the 427 sohc timing cover gaskets laid out on a bench so i can see what i have or what i am missing?have an idea of what they look like but would be nice to see them not on the engine but on a table so i can be clear on it?
pumpbldr
Re: sohc timing cover gaskets
« Reply #1 on: July 02, 2026, 06:47:07 PM »
Here is a picture of the timing cover gaskets. You will notice there is 3 "U-shaped" ones that go on the end of the head. You only need 2. One of them gets parked depending on Early or late heads. Hope this helps.
Doug aka pumpbldr
Precision Oil Pumps
hbstang
« Reply #2 on: July 02, 2026, 10:54:22 PM »
thank you doug for the pictures it helps a lot.did you have any in stock?
also do you need gaskets on both sides of backing plate every where?
