Author Topic: 1966 Cyclone Z bar question  (Read 832 times)
c9zx
« on: June 24, 2026, 03:36:45 PM »
I removed the equalizer bar from my 1966 Cyclone 390 car. The width is spring loaded and adjustable. The frame side has a .990 ball and the block side has a .630 ball. I'm hoping some of the Fairlane and Comet members can tell me if this is correct for the car. The listed reproduction at Auto Krafters is not adjustable. The site doesn't like my photo extension for some reason. Any insights will be appreciated. Thanks, Chuck
1969 Eliminator G code
CSX-7031 FIA Cobra
2007 Mustang GT, Whipple
1966 Cyclone GT
GerryP
Re: 1966 Cyclone Z bar question
« Reply #1 on: June 25, 2026, 05:10:47 AM »
That is correct.  Crites did make a replacement z bar that was a solid piece.  I don't know if that's what Autokrafters is selling.  You can still buy the nylon bushings.
6667fan
  • Every Second Counts
« Reply #2 on: June 25, 2026, 10:12:50 AM »
Be wary of the one piece unit.It does not install easily and the one I have here is .250 longer than an assembled factory unit.
If you don’t have some old school pressure plate that takes a lot of leg pressure to release the clutch you will probably be okay with stock components. Examine where the arms attach to the center tube halves. I have had several where decades of use cycles have fatigued the weld point where the curved arm that goes under the steering column attaches to its respective half.
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
oldiron.fe
« Reply #3 on: June 25, 2026, 02:53:42 PM »
       in 1967 my 427 needed a strong clutch often 4500/5000 drops- the linkage started to bend/etc. i took 3/8 round rod and brazed/formed reenforced all the arms and rods and fit with jardene        headers -- often checked/replaced the block/frame pivots- had made bushings - metal under dash too      if you have apart it is easy to do now and elimate any future problems --also check all the     supporting brackets and firewall for cracks from the heavy clutch and brake use you may find breaks around bolts/welds from old heavy clutch use --if old racer    john
66' Fairlanes 427 (08/26/67- present)
66/67' Fairlanes
70' Mustang Fastback
66' Dually
c9zx
« Reply #4 on: June 26, 2026, 07:18:30 AM »
Thank you all for the replies. It is good to know I have the correct parts. I will wait until the engine and headers are installed to see where I can add extra bracing. Thanks, Chuck
CSX-7031 FIA Cobra
1966 Cyclone GT
