Author Topic: valve spring pressure for sohc heads  (Read 593 times)
hbstang
« on: June 03, 2026, 01:01:25 PM »
what is everyone running for valve springs on ford sohc heads.cams will be 282 and .610 lift from racedyne/lsm and jays rockers,new t&d shafts etc.tool steel lw retainers and custom ss intake exh valves.2.350 intake and 2.100 exh valves.
maybe 7k rpm max 489 sohc.in general seat pressure etc.valves are 11/32.
Re: valve spring pressure for sohc heads
« Reply #1 on: June 03, 2026, 01:10:56 PM »
No duration split?  Leaving a lot of power on the table there...
No idea on spring loads without knowing the rest of the cam specs.  Lots of info missing.
