Author Topic: 363” FE for sale. 500 hp/ 440 tq  (Read 2116 times)
CaptCobrajet
« on: May 25, 2026, 11:43:15 AM »
I built this engine for a ‘64 Rayson Craft V-drive boat that I have.  We just ran it on the dyno.  I like it so good, I think I am going to do some more of these, so I am going to sell this one.  Here’s what it is……started life as a standard bore 390 block.  Honed to 4.062.  CP pistons, Molnar 6.540 length FE rods.  3.5 stroke iron crank.  .600 lift, 240/248-112 very streetable hyd roller with Crower HIPPO solid rollers, tight lash.  9-10 inches vacuum at idle.  BBM heads, 2.150/1.660 valves.  T&D single shaft rockers, PAC springs, Manton pushrods.  Canton street/strip T-pan, screen windage tray.  11:1 static CR but it tolerates 93 octane.  New Duraspark distributor custom curved, with a little bit of vac advance.  TFS tunnel wedge, and two 550 cfm Low Riser clone carbs I got from AFS.
Peak torque 440 at 4600 rpm .  Peak power 509 at 6900 rpm.  Lots of nice parts in a driveable combo.  I think it would be outstanding in a Cobra, or other manual shifted street car.  It’s a 500 hp piece that is easy on gas when you are not into it.  It cruises nice at 2500-3000 rpm with light load on my dyno.  We put several pulls on it, and tuned it for WOT and also for light cruise and idle manners.  $17500 ready to go in the crate.  If interested, email me at blairpatrickfe at gmail dot com.  Thanks
Blair Patrick
