Author Topic: Need some info on old Crane FT cam for 390-428....  (Read 779 times)
427LX
« on: May 13, 2026, 07:42:23 AM »
A friend brought it by to see if I could find info on it. Numbers stamped on rear journal are HIT-290-NC  and 34 26 91.  Has been run a short time but lobes and all look in very good condition.
He wants to run it in a 390 he is building and I told him if so buy the BEST lifters you can find thru Bullet cams or Howards and make sure they spin freely in the bores. He does not have the original lifters.  Thanks for any help. Now I could set it up in my lathe with my cam check setup but thought I would check here first and determine whether it is a hyd. or solid grind.
« Last Edit: May 13, 2026, 07:44:19 AM by 427LX »
pbf777
Re: Need some info on old Crane FT cam for 390-428....
« Reply #1 on: May 13, 2026, 11:16:12 AM »
HIT-290-NC
     It is a "hydraulic" grind.  One of the "High-Intensity" series.
     Specifications:
     290 adv. x 234 @ .050" x .563" lift x 114 L.C.L. (symmetrical)
     Actual Part Number:  344621;  But note,  it seems that Crane apparently reused that number later for a different grind!   ;)
     Scott.
« Last Edit: May 13, 2026, 11:34:33 AM by pbf777 »
427LX
« Reply #2 on: May 13, 2026, 12:16:15 PM »
Many thanks for that info Scott!
