Author Topic: 605" SOHC, 1040 HP, 846 Tq  (Read 1919 times)
« on: May 08, 2026, 08:35:38 AM »
Performance Summary:
      Cubic Inches:      605         Dyno brand:  Superflow 901
      Power Adder:     None          Where dynoed:  FE  Power
      Peak Horsepower:  1039.9  @ 6900
      Peak Torque:  843.7@5000, 846.2@5900 (?, may be a blip in the curve)
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:
Shelby aluminum block, 4.500" bore, offset bored to a 4.700" bore spacing,
Darton sleeves with O-ring grooves, SCE O-rings for copper head gaskets
   Crankshaft brand, cast or forged, stroke, journal size:
Crower billet crank, throws moved to line up with the spread bore spacing, stock main
journal size, 2.100" rod journal size
   Connecting Rods brand, material, center to center distance, end sizes, bolts:
Crower billet SBC rods, 6.625" length, .927 pins
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:
CP forged pistons, designed to work with offset bore (the dome on
the pistons is moved to line up with the heads), 13:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:
125M Main bearings, Clevite rod bearings
   Piston rings brand, size, other notes:
Total Seal rings, steel top 0.9mm, Napier 2nd 0.9mm, 3mm oil ring
standard tension
   Oil Pump, pickup, and drive:
Peterson Fluid Systems 6 stage dry sump pump
   Oil pan, windage tray, oil filter adapter:
Custom fabricated oil pan and windage tray
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050")
Comp SOHC cams, 323/315 advertised, 296/288 @ .050, 114 LSA, .739/.739 lift
   Lifters brand, type:
Not required ;-)
   Timing chain and timing cover:
Pond timing cover, gears, and chain
   Cylinder heads brand, material, port and chamber information:
No-name heads,  welded to raise intake and exhaust ports, fully ported
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700   465            .700   330
      .800               .800
   Flow bench used, location:
Superflow, R&R Performance
   Intake valve brand, head size, stem size:
Trick Titanium, 2.35", 11/32"
   Exhaust valve brand, head size, stem size:
Trick Titanium, 1.900", 11/32"
   Valve springs brand, part number, specs:
PAC springs, 190 on seat, 540 open
   Retainers and locks brand, part number, specs:
PAC tool steel retainers, Manley locks
   Rocker arm brand, type (adjustable or non-adj), material, ratio
FE Power non-adjustable rockers, stock ratio (~1.3:1)
   Rocker shafts and stands, brand, material:
Precision Oil  Pumps shafts
   Pushrods brand, type, length:
Just say NO to pushrods.
   Valve covers, brand, type:
Blue Thunder
   Distributor brand, advance curve information:
Distributorless ignition, crank and cam sensors, 38 total
   Harmonic balancer brand:
ATI
   Water pump brand, type (mechanical or electric):
CVR Electric Pump with FE  Power adapters
   Intake manifold brand, material, porting information:
Fabricated sheet metal intake
   Carburetor(s) brand, type
Accufab Dominator throttle bodies (2), Ford Racing 80# Injectors
   Exhaust manifolds or headers brand, type:
Custom built headers for chassis, 2-1/8 to 2/1/4 to 2-3/8 step,
merge collectors with 3" choke
« Last Edit: July 25, 2026, 07:54:31 AM by jayb »
475fetoploader
Re: 605" SOHC, 1040 HP, 846 Tq
« Reply #1 on: May 08, 2026, 12:50:39 PM »
well thats a beast.  Im guessing that was frustrating at times, but a really enjoyable project.  It's really quite an achievement.
1967  519 c.i.  TKX 5 speed
« Reply #2 on: May 08, 2026, 03:31:49 PM »
1000 HP and 605 cid at 7500 must sound wicked.  nice work.
Royce
« Reply #3 on: May 11, 2026, 08:12:52 AM »
No name heads  lol.. A name that will never again be mentioned on this forum.
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
KMcCullah
« Reply #4 on: October 10, 2026, 09:58:19 AM »
I calculated 4.750 Stroke! Amazing what can be done with the cam missing.  8)
Kevin McCullah
Stangman1
« Reply #5 on: October 11, 2026, 03:34:53 PM »
Great HP but torque is brutal all across the board.
Thumperbird
« Reply #6 on: October 11, 2026, 06:51:03 PM »
OK, call me dense, what's the deal with heads?  Are these your's Jay?  Custom for the SOHC or ?
« Reply #7 on: October 12, 2026, 10:28:26 AM »
Just say no to pushrods ..lol.. nice numbers especially considering the only .739 lift
« Reply #8 on: October 12, 2026, 02:29:59 PM »
All I want to say is if you are ever in the market for SOHC heads, contact me first - Jay
« Reply #9 on: October 12, 2026, 03:14:30 PM »
Is no-name still making heads?
66FAIRLANE
  • Andy
« Reply #10 on: October 12, 2026, 06:33:07 PM »
That's one serious piece!
« Reply #11 on: October 13, 2026, 02:23:34 PM »
No, but he is still trying to sell them  >:(
