Author Topic: large drum brake kits for 60's - 70's Fords  (Read 1101 times)
TS69GT500
« on: April 29, 2026, 03:00:33 PM »
Has anyone installed one of the large rear drum brake kits as offered by Ford Racing and others on their classic fords with power brakes?  11 in x 2.25
I know most kits only fit the late model large bearing flange although I think some are offered to fit small bearing housings.
I assume the wheel cylinders are either 1 in or 1x1/8 and the master cyl must be matched to provide increased volume.
If anyone has done this upgrade what master cyl did you use and was a "residual valve" required?
Basically, was this a simple swap parts upgrade?
Thanks,
TonyS
mike7570
Re: large drum brake kits for 60's - 70's Fords
« Reply #1 on: April 29, 2026, 05:32:02 PM »
I miss the trips to “Pick Your Part” auto salvage back in the 70’s and 80’s searching for neat stuff to use on my   my street car or race car. One particular trip we found the large drum brakes from a station wagon (I think in that size) and they were basically a bolt on to my 9” rear end. Used the original mustang power brake master cylinder and they worked just fine.
« Reply #2 on: May 12, 2026, 07:22:24 AM »
Open Tracker sells brake kits 11 x 2.25 large and small bearing 8 and 9 inch rear diff, I'm getting ready to do mine but haven't ardered anything yet but I'm going to use the master cylinder that comes in the KH front brake kit
https://opentrackerracing.com/
« Last Edit: May 12, 2026, 07:26:30 AM by e philpott »
