Author Topic: 462 pump gas  (Read 2565 times)
c9zx
462 pump gas
« on: April 22, 2026, 07:11:14 AM »
Performance Summary:
      Cubic Inches:   462            Dyno brand:Yourdyno mated to Land & Sea Brake
      Power Adder:     none          Where dynoed:Brand Racing Engines
      Peak Horsepower:655.7
      Peak Torque:607.4
Horsepower and Torque Curves:Power above 400 from3800 to 4400, above 500 4500 to 5300, above 600 5400 through end of pull.
Engine Specifications:Ford A scratch with billet cross bolt mains on 2, 3, and 4. 4.160 bore
   Block brand, material, finished bore size, other notes: I got most of the parts from Lykins Motorsports. Good prices, fast shipping, and a lot of very helpful advice and information.
   Crankshaft brand, cast or forged, stroke, journal size: Scat 9000 turned .010/.010 to make it straight
   Connecting Rods brand, material, center to center distance, end sizes, bolts: Molnar forged H beam, 6.800"
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:Mahle forged, 20cc dish, 10.44:1 SCR
   Main Bearings, Rod Bearings, Cam Bearings brand and size: Clevite race, Durabond
   Piston rings brand, size, other notes: Mahle 1mm, 1mm, 2mm
   Oil Pump, pickup, and drive: Mellings HV, ARP
   Oil pan, windage tray, oil filter adapter: Canton 8 quart T pan with trap doors, Ford C8 adaptor
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050") Comp solid roller, custom from Brent. .703" Int., .676" Exh., 253/264 @ .050. LSA 109, ICL 107
   Lifters brand, type:BAM modified to oil through pushrods
   Timing chain and timing cover:Cloys billet, 9 position sprocket
   Cylinder heads brand, material, port and chamber information: TFS, CC @ 71cc
   Cylinder head flow in cfm at inches of lift (28" H2O pressure drop): I don't have this information, I wish I did.
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location: JDC heads and intake
   Intake valve brand, head size, stem size: TFS
   Exhaust valve brand, head size, stem size: TFS
   Valve springs brand, part number, specs:
   Retainers and locks brand, part number, specs:
   Rocker arm brand, type (adjustable or non-adj), material, ratio Harland Sharp 1.76:1, aluminum
   Rocker shafts and stands, brand, material: Harland Sharp, steel
   Pushrods brand, type, length: Smith Brothers, 3/8" .141" wall, ball & ball
   Valve covers, brand, type: Chrome steel pent roof
   Distributor brand, advance curve information: MSD billet race. all advance in by 2700 RPM
   Harmonic balancer brand: Durabond
   Water pump brand, type (mechanical or electric): Dyno electric
   Intake manifold brand, material, porting information: Edelbrock Performer RPM ported by JDC
   Carburetor(s) brand, type single Holley "950", List 80498
   Exhaust manifolds or headers brand, type: Cheap truck headers from Jeg's, 1.75" primary, short 3" collectors, 28" tubes.
« Last Edit: April 22, 2026, 07:58:59 AM by c9zx »
1969 Eliminator G code
CSX-7031 FIA Cobra
2007 Mustang GT, Whipple
1966 Cyclone GT
Re: 462 pump gas
« Reply #1 on: April 22, 2026, 07:15:33 AM »
Nice build !
c9zx
Re: 462 pump gas
« Reply #2 on: April 22, 2026, 08:00:37 AM »
Thanks. I had to learn and re-learn a LOT. I had not touched an FE since 1978.
CSX-7031 FIA Cobra
1966 Cyclone GT
Re: 462 pump gas
« Reply #3 on: April 22, 2026, 08:56:50 AM »
Very stout!
Re: 462 pump gas
« Reply #4 on: April 22, 2026, 09:16:00 AM »
That is a stout one!
c9zx
Re: 462 pump gas
« Reply #5 on: April 22, 2026, 11:50:21 AM »
Thanks Brent. I got a lot of advice and information from you as as tons of great parts. Thanks for the help. Chuck
CSX-7031 FIA Cobra
1966 Cyclone GT
475fetoploader
Re: 462 pump gas
« Reply #6 on: April 22, 2026, 09:10:08 PM »
That thing is happy, what is it landing in?
1967  519 c.i.  TKX 5 speed
c9zx
Re: 462 pump gas
« Reply #7 on: April 23, 2026, 03:18:56 PM »
It is going into a 1966 Cyclone GT 4 speed, assuming I can eventually get the Doug's headers installed. :)
CSX-7031 FIA Cobra
1966 Cyclone GT
6667fan
  • Every Second Counts
Re: 462 pump gas
« Reply #8 on: April 25, 2026, 09:07:14 PM »
Congrats on getting the engine done.
 At the point you embark on installing the engine/trans/headers I recommend getting a notebook going. Talking about building a cheat sheet for the what goes first, second, etc.
If you have to do it again in the future you will have your own experience memorialized to draw upon.
Are the Doug’s you have individual tubes with slip on collector or a contiguous flange version?
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
c9zx
Re: 462 pump gas
« Reply #9 on: April 26, 2026, 08:30:38 AM »
Should I include the swear words in the log? (kidding) A good suggestion, thanks. The right side is one piece. the left side is two piece. 5 and 6 slide on to 7 and 8 (Doug's PN 625S). I'm not sure of the best way to approach the installation. I have a drive on lift but I'm not sure that the ramps won't get in the way. Any suggestions would be appreciated.
CSX-7031 FIA Cobra
1966 Cyclone GT
TwoFifty
Re: 462 pump gas
« Reply #10 on: April 27, 2026, 10:03:13 AM »
Great results!  Would you be willing to share how high you had to spin it to make that power?  (or willing to share a copy of the dyno sheet?)  :)
Thanks and congrats! -Jim
c9zx
Re: 462 pump gas
« Reply #11 on: April 27, 2026, 11:18:47 AM »
6400 RPM. I'll post the sheet when I can. Chuck
CSX-7031 FIA Cobra
1966 Cyclone GT
