Author Topic: Those "new" summit fe HYD roller cams.  (Read 7004 times)
DuckRyder
« on: April 12, 2026, 03:11:34 PM »
Am i missing something here?
  • The numbers don't jive on the Wallace calculator?
  • All the lobes from 212@.050 to 248@.050 are .587 lift?
For instance the HR 3 / Summit 8917
In order to get the numbers it has to be 279 advertised on the intake and a 108.5 ICL (cam card 278/107)
While  realize that its very possible to have multiple lobes of the same lift with different durations, that seems pretty weird for all the lobes in the line to be the same lift and of 7 different durations. I don't really recall having seen that in other cam lines....
Any thoughts on this?
Robert
galaxiex
Re: Those "new" summit fe HYD roller cams.
« Reply #1 on: April 12, 2026, 03:46:30 PM »
I've found Summit sometimes makes or has, errors in some of their technical descriptions.
May not be Summit's fault... might be the tech sheet/specs from the manufacturer.
Seems like someone doesn't proofread those things sometimes...
mygasser
« Reply #2 on: April 12, 2026, 04:28:30 PM »
i'll let you know how it goes later this year, i've got one on the way that i ordered a couple days ago. i say later this year but it depends how the temporary (used) 360 runs when we fire it this week. if it's ok it'll go in my gasser til the end of the season, if not i'll be building up the 390 a bit sooner, lol.
neil.
« Reply #3 on: April 12, 2026, 05:32:24 PM »
One guy is designing the lobes and they have a new in-house Landis grinder.
DuckRyder
« Reply #4 on: April 13, 2026, 06:49:04 AM »
So it seems Brian Nutter is the guy designing the lobes.(cant find a ton about him)
At least where they are talking about LS cams they claim the billets are US made and that the Landis produces a very good and accurate finished lobe. (who else is using those? Comp?, Howards?) Again talking about "PRO LS" cams its sounds like they are even machining the billets and doing the hardening.
Anyway... somewhat intriguing if true.
Robert
« Reply #5 on: April 13, 2026, 08:05:01 AM »
It is Brian Nutter.  I've competed with him in the cam challenge stuff.
All of your higher end cam grinders will have a CNC grinder like that.
Having experience in a specific engine family is what gives you a leg up with cam stuff.   Just my opinion, but it's hard to pop out a line of cams when you've never built/dyno'd a specific engine before.  Lots of different aspects when you look at valvetrain weights between cylinder heads, valve sizes, displacements, etc.
DuckRyder
« Reply #6 on: April 13, 2026, 06:22:10 PM »
Completely agree with you Brent, i just find new stuff for the FE interesting, particularly not so racy stuff.
Most of these seem to be aimed at stockish engines because they talk about things like "stock heads", "stock pistons", which makes sense for Summit. I do feel like  got some things right for the "typical fe" like the increased split in durations which is probably the right direction for most OE heads.
The other thing is the math doesn't math on the cam cards, as mentioned this could just be a mistake, but every one I've tried to run the numbers on has not come up matching the cam card. That brings questions of course, and is IME very atypical.
Robert
« Reply #7 on: April 14, 2026, 03:59:25 AM »
I don’t like quick moves on heavy valved engines.  Would have to put a lobe on a doctor to see 110% what’s going on, but in a lot of cases the HI is a decent indicator of how quick things are.
I feel like a lot of the Ford stuff is lumped together, even saying BBF/FE on their website.
« Reply #8 on: April 14, 2026, 09:06:38 AM »
I 100% agree with Brent
In the end, assuming they hit their numbers, quality is good, and the cores are available etc, IMO these are certainly a little better than most of the common off the shelf cams.  No idea why their numbers are off, but you are correct.  Could be an asymmetric lobe, differences in putting a lobe family on an FE core, or just bad documentation or a combo of all of it.
However, with these cams for the discount, you give up lift, which likely drives some spring choice changes as well as the obvious flow loss.  You give up some seat-to-seat timing, which with a normal retainer and 3/8 valves will want some extra pressure.   What I don't like is you have to go small to get overlap low enough to have decent vacuum on a street build, it'd be nice to have some wider LSA options.
Assuming the lobes are controllable, some spread on those bigger cams would be better for a stroker but given the lift and seat timing it'll still be a power cost over a custom.  Saving 200 bucks is 200 bucks, but it comes with a cost.
On the flip side, there seems to be some decent split, good for stock or TFS heads, although maybe a bit excessive on a couple.
I would be hard pressed when digging deep into all the other blueprinting to recommend a generic cam, but if quality and availability holds, I can see a market for these
« Last Edit: April 14, 2026, 09:19:17 AM by My427stang »
« Reply #9 on: April 14, 2026, 11:57:50 AM »
Brian is a very sharp dude.  He has a lot of years in the industry - although little direct FE experience.
H put in a lot of time at Wiseco doing pistons before moving to Summit.
DuckRyder
« Reply #10 on: April 17, 2026, 12:55:02 PM »
Agree with points about quick events and overlap/LSA.
Robert
DuckRyder
« Reply #11 on: April 30, 2026, 02:37:04 PM »
I emailed Summit nearly a week ago asking for an explanation of the anomalies including My Gassers cam card not matching the one for the same cam on SummitRacing.com.
So far no reply other than the automated "we got your question" e-mail.
Robert
mygasser
« Reply #12 on: April 30, 2026, 03:56:07 PM »
did you title your email 'fao brian nutter, cam grinder'?
DuckRyder
« Reply #13 on: April 30, 2026, 07:10:12 PM »
Not exactly, but i said someone needs to get with him and straighten it out...  :-X
Robert
pbf777
« Reply #14 on: May 01, 2026, 11:26:19 AM »
. . . . . . asking for an explanation of the anomalies including My Gassers cam card not matching the one for the same cam on SummitRacing.com.
    I'm not looking at the specific instance at hand, but having a camshaft "as measured" not matching the sales literature wouldn't be anything new!  Now, hopefully somewhat close would be nice, but some deviation often is exhibited because that lobe was originally profiled for a different engine make, most often of a different lifter face (flat-tappet) or roller-wheel presentation which has an effect.   ;)
    If measuring at the valve, then there are many other possible aspects that may be unique to different engine valvetrain iterations which may influence the outcome also.   :-\
    Scott.
