Author Topic: Doug Nash C-6 overdrive with pictures added.  (Read 1168 times)
gregaba
« on: April 07, 2026, 07:22:33 AM »
Still cleaning out my shop and found a complete OD unit.
The only thing it needs is a main shaft bearing which is the same as the top loader main shaft bearing. It turn's good but I noticed a catch while hand turning it.
Has the C-6 tail shaft and stubby drive shaft.
The only thing I don't have is the under dash mounted  cable control which you can buy at any truck supply storeand the speedo cable broke in half but will include the old one so you can make a new one..
$650.00 plus shipping.
If any interest I will post picture's.
The pictures with the case cracked open I took not wanting to break it open but decided to open it up for another inspection.
It will need some bolt's that have been lost and 1 washer under one of the gear set's.
I do have somewhere all the assembly manuals and part's numbers you will need to assemble.
Greg
« Last Edit: April 08, 2026, 11:34:49 AM by gregaba »
