Author Topic: FE Performance Top-End Parts-Ported heads,crower lifters,FPP Rockers,Ignition  (Read 3400 times)
BlueDemonMuchoPower
Selling components from a strong running Ford FE solid roller combination that was removed years ago and stored indoors. I originally planned to reuse these parts but decided not to rebuild the engine.
These are not stock take-off parts, these were part of a serious 428 performance engine.
- Ported FE Cylinder Heads - C7AE-A. $450 Heavily ported, 2.16 intake valves and 1.6 exhaust valves, performance springs, machined for high performance use. Has a small crack (see photos) in a head bolt boss, just in the outer edge, repairable, it doesn't extend to the deck surface or combustion area.
- Shaft Rocker System $500 Genuine Ford Power Parts (FPP) shaft-mounted roller rockers. Oiled. One rocker is a different brand but same ratio and never caused issues. They all roll smooth.
- Crower Solid Roller Lifters - $450 solid roller lifters, .875 diam. Tie-bar design,  stored oiled indoors, all roll smoothly.
- Mallory Ignition - $150 Mallory Comp 9000 distributor unilite breakerless ignition and HyFire IVA Ignition Box, unable to test but removed working.
Everything is located in San Diego, CA. I can ship anywhere in the U.S. at buyers expense.
« Last Edit: February 10, 2026, 11:08:23 AM by BlueDemonMuchoPower »
Maybe I’m looking at it wrong but the cracked part of the heads is the head bolt hole not the pedestal pad.
BlueDemonMuchoPower
Stangman I think you are right, I corrected the post.
