Author Topic: Adjustable rocker arms and valve covers  (Read 4093 times)
Hotrodjohn71
« on: January 21, 2026, 01:39:18 PM »
Are pent roof valve covers required for stock adjustable rocker arms?
Thanks
mike7570
Re: Adjustable rocker arms and valve covers
« Reply #1 on: January 21, 2026, 02:54:23 PM »
No, I had them under a “powered by ford” chrome cover. However with all the different valve covers available you should double check to make sure.
« Last Edit: January 21, 2026, 02:58:18 PM by mike7570 »
« Reply #2 on: January 21, 2026, 08:42:59 PM »
You don’t necessarily need the tall pentroof valve covers to work with stock Ford adjustable rockers, but there are some Ford valve covers that won’t work as-is.
The common ‘65 to mid ‘67 short angular FE valve covers won’t work. Some people mistakenly call those “pentroof” but they’re not the same as the tall pentroofs.
The early round top & “baldie” valve covers will work. And like Mike said the mid ‘67 & later “Powered by Ford” valve covers will work.
If you start adding aftermarket roller rockers then the choices can get more complicated.
« Reply #3 on: January 22, 2026, 08:06:28 AM »
Roller rocker arms are where you'll have interference trouble
Hotrodjohn71
« Reply #4 on: January 22, 2026, 11:06:21 AM »
Thank you! I greatly appreciate it.
