Author Topic: 1960 Starliner Y Code  (Read 14224 times)
« on: January 17, 2026, 08:52:30 PM »
I bought this, last year and it's slowed the chassis work on my Austin Healey but, I'm having fun.
This is my second '60. I had a Galaxie Club Sedan from '64 until about '70. It was one of my favorite cars of all time and definitely my favorite full size Ford. I just had to have another and this one is a real jewel! Not that it's in great shape. It's not, as it has a lot rust you can see but, I am only the third registered owner. It was sold new in Portland OR, then sold to the guys son in WA and I bought it there.
It could be as close a clone to a original HP 360 as you can get but, I won't keep it as a 352. It will wind up, between 390 and 412 cid. I want to stay in that range for reasonable mileage so, I can drive it a lot.
Right now it has the original heads and intake but, this spring, it's getting a set of C3AE-C heads (67cc & CJ valves) and a 390 HP intake and short headers, with 2.5 exhaust. No cam change but adj rockers. When looking under the car, I found that the block is a C3AE-E so, they will at least match :) I measured the stroke but, I won't know the bore, until I replace the heads. last, before the end of Spring, I'm hoping to get a 4.11 third member built, to go with the T85 OD trans.
In the engine compartment, I put a oval air cleaner, on top of a 390 PU, 600 cfm Holley. I had to replace the fuel pump after I replaced the fuel tank with a high volume AC pump, because the fuel part of the dual diaphragm pump was bad and I had it, on hand. I then had to add a electric vacuum pump, for the windshield wipers. I also installed a 1 wire alternator.
I also got a good deal on a pair of 275 60 15, Nitto drag radials.
Re: 1960 Starliner Y Code
« Reply #1 on: January 18, 2026, 07:21:31 PM »
Regarding the rust, the rocker panels are of course rusted threw. I bought new ones and I've been waiting since Nov to get them installed.
The interior isn't as bad as it could have been. It was safe to step on the floors but, plenty of rust. This is the way I fixed it, with riveted panels. I've killed the rust in the seat area and it's painted, too.
Also pictures of the '60 Galaxie I had many years ago.
« Reply #2 on: January 19, 2026, 03:58:45 PM »
This is what it looks like now. The upholstery is done but, I don't want to put it in, until the rocker panels are finished.
A picture of the another set of Nitto tires, 275 50 15 on 10" Centerline wheels.
CDXXVII
« Reply #3 on: January 19, 2026, 06:36:37 PM »
Did you buy the rocker panels from Auto Metal Direct?
« Reply #4 on: January 19, 2026, 07:29:49 PM »
No, I bought them off Ebay.
I just did a search for "1960 Ford Galaxie rocker panels" they had no results so, I did a search for 1960 Ford Galaxie and they have hardly anything for the '60.
« Last Edit: January 19, 2026, 07:36:33 PM by frnkeore »
allrightmike
« Reply #5 on: January 29, 2026, 05:16:11 PM »
I like your result with the floor repair. My Starliner was in similar condition, had to get it on a rotisserie. Was a 352 2v automatic, now is a 427 top loader, a blast on the road. At a car show only the lucky guessers know what it is. I'll try to add photos. Best luck with your project!
'60 Starliner 427 4speed.
« Reply #6 on: January 29, 2026, 05:48:12 PM »
Thank you, Mike. Yours is a beautiful Starliner, I like it.
Did you delete the aluminum trim between the tail lights? If so, could I get a picture of it. I may have to do it to mine.
allrightmike
« Reply #7 on: January 29, 2026, 07:47:05 PM »
Yes I did, my opinion is in the case of the '60, the less gingerbread the better. I also eliminated the backup lights with LED lights across the top of the license plate. Sending you a photo.
« Reply #8 on: January 29, 2026, 08:07:21 PM »
thank you. My 2 trim pieces are BADLY corroded so, I was thinking of doing that, too.
Tell me about your power steering. I need to convert mine.
allrightmike
« Reply #9 on: January 29, 2026, 09:20:13 PM »
It is a Borgeson unit.
