Author Topic: isky sohc cams  (Read 4625 times)
hbstang
isky sohc cams
« on: December 12, 2025, 04:08:46 PM »
have a pair of isky so-12000 cams,catalog shows opening and closing and adv duration,but not sure how they would work on a na build.here is the specs if anyone can determine the duration at .050 .may have to wait untill the cams are degreed to get if they are usable in my build.the cams are in good condition and could be used as is.
« Last Edit: December 12, 2025, 04:11:00 PM by hbstang »
Re: isky sohc cams
« Reply #1 on: December 13, 2025, 05:45:01 AM »
A good lobe catalog will show a theoretical checking duration and a duration at the valve.  With SOHC engines, the cam is degreed at the valve, not on the lobe like a traditional engine.
hbstang
Re: isky sohc cams
« Reply #2 on: January 30, 2026, 02:24:51 PM »
so i have another set of cams that are lsm on the box.they are new,and i had isky run them on there profile machine,and was wondering if these would work good in a 489 sohc street engine with approx 11-1 compression.i cant tell much myself from the printouts,but i know they are 282 at .050 duration ans about .610 lift.will not run over 7,000 rpm and have dual plane factory intake.also not sure about carbs but originals are maybe out of my range on price.
« Last Edit: January 30, 2026, 02:28:08 PM by hbstang »
Re: isky sohc cams
« Reply #3 on: January 30, 2026, 02:41:16 PM »
The information you have there is more related to how each lobe is designed, getting down to velocity, acceleration, jerk, etc.  A lot of data is missing.
On an overhead cam engine, you have to have a lot more information, usually checking duration and duration at the valve.
