FE Technical Forum
Block came with NO 427 Side Spacers (Spacer Fitting)
Topic: Block came with NO 427 Side Spacers (Spacer Fitting) (Read 3320 times)
dozz302
Full Member
December 06, 2025, 12:45:51 PM »
Hello, When fitting the spacers in a 427 block (block came without spacers), if all torqued down and crank spins freely are you good to go? I have been picking up spacers at swap meets and have an assortment.
MeanGene
Re: Block came with NO 427 Side Spacers (Spacer Fitting)
Reply #1 on:
December 06, 2025, 04:17:15 PM »
Ford only made 3 thicknesses of spacers, so if your block has the original caps and you have a handful of original spacers, just select them with a snug but not forced fit
Reply #2 on:
December 06, 2025, 04:32:06 PM »
If this is a high performance or high value build, it would sure be nice to do an align hone or at least check clearances. Most of the ones that come through here are pretty crooked
FE Technical Forum
