Author Topic: C5AE 390 block cast with cross bolt bosses  (Read 25738 times)
63ragtop
Re: C5AE 390 block cast with cross bolt bosses
« Reply #15 on: October 24, 2025, 08:56:49 PM »
Frank just an upside down 352 on the bulkhead, a 5c10 date a real small c5ae-a
Urgefor
« Reply #16 on: October 24, 2025, 10:24:15 PM »
Urgefor,
Do you need the C5 and/or the bosses for a specific reason?
Mostly to make my life a bit easier.  I have a '64 block with the bosses but the project car is a '66. I've fabricated some motor mounts to make it fit but it just "bugs" me a bit. Long story short, I was not aware some C5 blocks were cast like that also.  If I can get a C5 block with bosses and extra material in the webs like the '64 block along with the 4 bolt engine mount pattern, it would be a win/win for me.  I have a couple C6 engines.  To be more precise, one engine (from a country squire) along with a complete drivetrain from a '66 Galaxie that was a real man's car.  4bbl, 4spd, no air, no power brakes and no power steering.   :o
« Last Edit: October 25, 2025, 06:46:22 PM by Urgefor »
« Reply #17 on: October 25, 2025, 01:59:39 PM »
Ross, does that block have a oil return in the skirt?
It does not
« Reply #18 on: October 29, 2025, 11:11:32 AM »
i have a nice std bore c5ae-a block with bosses and thick main webbing
Urgefor
« Reply #19 on: October 29, 2025, 01:24:53 PM »
By chance have you seen this post in private classifieds?
For historical purposes, what is the casting date on your block?  Also, it sounds like Kevin would be interested in a picture of the C5AE-A casting on the block for information gathering he has been doing.
« Last Edit: October 29, 2025, 02:00:41 PM by Urgefor »
FERoadster
« Reply #20 on: November 01, 2025, 10:05:01 PM »
FERoadster here (now). Just got home this evening.
I was in Parker Colorado (near Elizabeth Co.) for the past 2 weeks and saw your message but couldn't reply because I didn't have my password. Message did go to my cell phone.
I will get photos tomorrow of each side, the front and rear bulkheads and the date code, I will also take a photo of the cross-bolt bosses and crow's feet area.
I'll post them on this thread.
Richard >>> FERoadster
FERoadster
« Reply #21 on: November 03, 2025, 01:50:54 PM »
Pictures attached.
Block has a date of 1964 and day of 9 but cannot tell the month. Would someone take a guess?
Block is C5AE-A and main saddle supports are the early style and not crow's feet (reinforced). It is a DIF block.
No other special info.
« Last Edit: November 04, 2025, 06:36:05 PM by FERoadster »
Urgefor
« Reply #22 on: November 03, 2025, 02:32:11 PM »
Thank you very much for the pictures Richard.  The letter denoting the month looks like a G(July) to me.
« Reply #23 on: November 03, 2025, 02:39:30 PM »
Your picture actually does show your block has the “crows feet” main webs.
And my guess would be “G” for the month also. A “4 C” would likely be too early for a C5AE-A block, and no other letter used would have that shape.
*And I’ll just edit to add - there is also usually a stamped assembly/test date code, often on one of the corner ears of the block, or on the front, and that will often help confirm the casting date code. Most common FE engines were assembled anywhere from a few days to a couple weeks after the block was cast.
« Last Edit: November 03, 2025, 03:05:29 PM by thatdarncat »
FERoadster
« Reply #24 on: November 04, 2025, 05:28:54 PM »
I didn't realize there are 2 or 3 "crow's feet" styles (Thanks Kevin) Here are 2 other types I've got. Also, the D4TE block date.
The C5 block I said was an old style since there is a window in the main saddle support. Just realized that the window is caused by the cross-bolt boss.
 I've got a 3rd type but couldn't get a good picture today.
Richard
« Last Edit: November 04, 2025, 05:36:50 PM by FERoadster »
« Reply #25 on: November 05, 2025, 12:41:21 PM »
Forgive me for asking the same question again, but I think maybe I didn't do it well last time, or I am not understanding the issue.
If you are using Billet Speedworks caps, or an equivalent pan rail to pan rail cap, why not use any 4-bolt motor mount block?  You'll be cutting back the bosses anyway unless you plan to narrow the caps, or narrow them and use spacers as well.
Some say locating off the pan rail is weaker, but depending on component weight, a 2 bolt main can swing 600 HP, 6000 rpm.  The caps are located off the register not the cross bolt, so you are really only grounding harmonics and adding another plane of stability, so they really shouldn't be any twisting force.  If this is going to be a bigger machine than that, I''d think the rest of the block is going to call uncle anyway
Seems like I'd pick almost any good 390 4-bolt block, make sure registers fit nice and tight on the parting line, light fit with the pan rail requiring maybe a little lube to slide in by hand for reference, and make the block choice and machining easy
Thoughts?
Urgefor
« Reply #26 on: November 05, 2025, 02:19:51 PM »
No need for forgiveness.  :)  For me, this thread is mostly about information gathering.  For example, prior to this thread, I was not aware that some 428 blocks cast in late '66/early '67 were cast with the bosses extra material in the web.
My 2 cents on the different block castings in relation to installing cross bolt caps in a nutshell.  While it isn't required (as you have noted) to have a block with the cross bolt bosses to install the caps and benefit from them, for whatever reason those blocks were cast with the bosses and extra material (crows feet) in the webs.  While not necessary by any means, it seems like a better base/foundation to start with if cross bolt caps are being added.  This, of course, assumes availability.  Sometimes you have no choice but to work with what is available.
