Author Topic: 541 cubic inch FE drag and drive  (Read 38093 times)
CaptCobrajet
« on: October 14, 2025, 11:00:59 AM »
1016 hp at 7700 rpm.  805 ft lbs torque at 5500 rpm.  It has 990+ horsepower for 1700 rpm up top.  Four digit power from 7000 rpm to 8200 rpm.  Shelby big bore block, Losito billet heads with a little love and valve job here.  4.500 Crower crank, CP pistons.  Dual three circuit 1050 Dominators.  We cammed it for making the Drag Week drive.  I think this engine would make 1100 hp with a 1-inch lift cam, but it wouldn’t make the street miles like that.  Pretty good like it is. I think my son is going to put it on our Facebook page and uTube when he gets the opportunity.
Blair Patrick
Re: 541 cubic inch FE drag and drive
« Reply #1 on: October 14, 2025, 11:34:01 AM »
Blair, tell us more about the heads and rods.
475fetoploader
« Reply #2 on: October 14, 2025, 02:36:53 PM »
You should probably put the big camshaft in, put it back on the dyno, just because....
On second thought never mind.  That's a very cool build.
« Last Edit: October 14, 2025, 02:43:50 PM by 475fetoploader »
1967  519 c.i.  TKX 5 speed
« Reply #3 on: October 14, 2025, 11:10:02 PM »
Dumb. How about a round about on the camshaft, less than 750 lift?
« Reply #4 on: October 15, 2025, 01:52:00 PM »
How do you make that crank stroke fit ? Nice power !!
XR7
« Reply #5 on: October 15, 2025, 05:57:54 PM »
   I was thinking the same thing! Hard to keep the rods from hitting the cam lobe even with a 4.375 stroke crank. Maybe a 1.888 Honda rod journal or SBC small journal 2.000 for rod clearance? Nice build and great power, should run hard in Scott's Cougar?
« Reply #6 on: October 15, 2025, 08:27:51 PM »
A 2.1" rod journal and SBC rod will make the 4.500" stroke possible.
CaptCobrajet
« Reply #7 on: October 16, 2025, 08:58:48 AM »
This one has a 2 inch journal.  It has about .040 clearance to the lobes on the back four cylinders.  The front four don’t get as close.  A 2.100 rod would not clear in this engine.  A 4.400 is as big as I have been able use with a 2.100 crank pin.
Joe, you are in the ballpark on lift.  The heads flow to 1-inch, and the ports are really big.  A little too big in my opinion.  I think the cross section is just about right for 600 inches, but it sure does come to life about 5500 rpm.  It is extremely long winded for the duration it has now.  A big boy cam would put peak power at over 8000 rpm.  Kinda makes me draw up a little to think of turning a 4.5 crank 8500 through the traps, lol.  It’s a neat combo like it is, and the valvetrain is all stuff that has worked for us before in Drag Week.  One thing about this cam being smallish for port and cubes is that it makes the torque and power curves really broad.  It gets near peak power at 7200 and just stays there past 8200.  Should be a neat piece for Jack and Scott to work with.
Blair Patrick
« Reply #8 on: October 16, 2025, 11:47:57 AM »
What is the intake valve size?
« Reply #9 on: October 17, 2025, 12:27:24 PM »
What a wicked build.  Incredible heads on top as well
hbstang
« Reply #10 on: October 17, 2025, 03:29:16 PM »
is that billet head an inline valve head?a lot of hp for an fe engine for sure.
« Reply #11 on: October 17, 2025, 10:42:27 PM »
Was looking at those cylinder heads Blair with a 280 cross volume do you need to be speeding or filling those runners.
« Reply #12 on: October 18, 2025, 03:32:34 PM »
I think probably almost 200 horse more than he had. She’s gonna scoot.
CaptCobrajet
« Reply #13 on: October 18, 2025, 06:43:35 PM »
Only 51 more HP than the last conventional Pro Port headed piece we had in it, but this thing has a lot more area under the curves.  It has its peak torque for almost 1000 rpm, and same with the power.  The billet head is a serious departure from the OE layout.  The valve orientation is the same, but they are canted and the ports are tilted.  Meanest head there is that bolts on the top of an FE block.  Some day I want to do a 4” crank in an iron BBM block and spin it about 10,000 rpm with heads like this.
Blair Patrick
« Reply #14 on: October 18, 2025, 11:19:59 PM »
What would be the benefit of a 4.0 crank than just using a 428 3.98 arm. Besides cubic inches.
