Author Topic: Anybody have any use for these?  (Read 5264 times)
« on: August 16, 2025, 10:47:00 AM »
These are brand spankin' new parts, left over from my small cube Tunnel Port project from several years ago.
I'll separate, sell together, whatever is necessary to get these out of here.  This combination was for a 397ci Tunnel Port (4.250"x3.500").  If you're crafty, you could make the pistons work with multiple configurations.  If you have a special build in mind, both parts could work for you.
*Pistons are brand new forged Racetec for a 4.250" bore, 1.150" compression height, .927" pin, 7cc dome.  Ring sizes are 1mm/1mm/2mm.
*Piston rings are brand new Mahle, 4.250" bore, 1mm/1mm/2mm.
*Rods are brand new R&R aluminum rods, 7.250" length, Honda rod journal (1.888), .927" pin.
Pistons/rods are assembled, but I can disassemble and sell separately if someone is interested.
I'd take $800 for all of it, offers accepted.  There's about $2400 worth of parts there.  Try me.
Glenn N
Re: Anybody have any use for these?
« Reply #1 on: August 24, 2025, 02:14:50 PM »
Brent, do you still have the 3.50" crank? Was it a FT steel? LMK thank you, Glenn
« Reply #2 on: August 24, 2025, 03:35:21 PM »
The 3.500" crank was a custom piece being made by Winberg.  At the 9 month mark, it was still not ready, so I canceled the order.
Glenn N
« Reply #3 on: August 24, 2025, 05:06:10 PM »
Oh wow sorry to hear that. Thank you anyway.
bsprowl
    • Ford FE Information
« Reply #4 on: August 24, 2025, 08:36:17 PM »
Would those work with a standard 3.5 crank?
« Reply #5 on: August 25, 2025, 04:48:13 AM »
No, they are a Honda rod journal.
