Author Topic: 427 sohc rockers  (Read 3720 times)
hbstang
427 sohc rockers
« on: August 14, 2025, 06:16:29 PM »
anyone know who makes these aluminum sohc rockers?are they any good,how do they hold up?
Re: 427 sohc rockers
« Reply #1 on: August 14, 2025, 10:13:30 PM »
Those rockers are from RAS, Rocker Arm Specialists.  I've heard that they went through several versions of those, trying to make them live.  I had a set that used small engine 2 stroke rod bearings, caged needle bearing type, that were used in the roller wheel.  On the dyno, my set lasted about 40 minutes before the needle bearings gave up and the rockers started coming apart.  My opinion of them is that they are pretty, but essentially junk if you actually want a running engine.
hbstang
« Reply #2 on: August 15, 2025, 01:28:13 PM »
well ok then,that tells me everything i need to know about them.will not buy them lol.thanks jay.i will have a lot more sohc questions as this project goes.
