Author Topic: Rocker stud problems  (Read 4678 times)
60sIron
« on: August 11, 2025, 02:17:27 PM »
So I've had a thread insert for a rocker stud pull out of my aluminum head.  It presented itself as an increasingly loud rattling noise.  I'm in the process of figuring out what I'm going to do, but I wanted to ask the community what causes this.  I torqued the studs to 40-45 ft lbs.  I assume if there was a coil bind problem it would have destroyed all the inserts immediately, not slowly over the course of a few hundred miles.  Interested in hearing your thoughts on this.  Hopefully I can fix this and it will stay fixed.
Re: Rocker stud problems
« Reply #1 on: August 11, 2025, 02:44:43 PM »
Head soft, too much spring load, coil bind, could be a number of things.
I pulled a couple of studs out of some Pond heads once, with about 600 lbs of spring load.
What kind of head is it?
60sIron
« Reply #2 on: August 11, 2025, 04:08:48 PM »
It is a BBM head, probably 2016 or 2017 vintage.
« Reply #3 on: August 11, 2025, 09:47:08 PM »
Did you torque the stud itself, into the head 40-45 ft/lbs, or did you torque the nuts to that amount?
TJ
« Reply #4 on: August 12, 2025, 07:14:02 AM »
Few month's ago another fellow had a similar problem.  Jay had a nice diy type fix if you have an old rocker assembly lying around.
https://fepower.net/simplemachinesforum/index.php?topic=12720.msg136806#msg136806
60sIron
« Reply #5 on: August 12, 2025, 09:48:35 AM »
The studs were just screwed in finger tight.  The nuts were torqued with the ARP lube that came with the kit.
