Author Topic: Bullock's Power Service - 347 SBF - pump gas - power brakes - 483 HP @ 6200  (Read 8832 times)
Here is a neat one, pump gas 347, but with a baby cam and a good set of heads and intake.  First time I have used the TFS Twisted Wedge 11R heads, I am usually an AFR guy, but they did well.  Most of the other parts in the engine are pretty cookie cutter.
The day was rough, incredible humidity and 95 degrees.  Need to go back to dynoing in the winter :)
The neat thing is we were looking for 450 HP, and right off the bat it spun 466 HP. Hung in stable to 6600 RPM over 8 pulls or so.  Despite a baby roller by most standards, only 216 degrees intake lobe, 54 degrees of overlap it pulled hard.  It will be relatively mellow with some chop from behind.
Neat change, we tried a Super Sucker and a poly spacer Brent wanted me to play with.  The Super Sucker gained a small amount, but the poly spacer immediately jumped 17 HP and 21 ft lbs.  Quite a surprise because we had just used it on a Victor equipped 620 HP 511 and it did well but single digit gains.
Engine use - Classic Mustang, a/c, PB, 5 speed, pump gas street car
Performance Summary:
      Cubic Inches:  347             Dyno brand: Stuska
      Power Adder:  N/A             Where dynoed:  Dale Meers Racing, Buffalo, KY
      Peak Horsepower:  483 HP @ 6200 (1 inch poly spacer), 466 @ 6000 (gasket only)
      Peak Torque:  447 @ 4800 (spacer) 426 @ 4800 (gasket only)
Engine Specifications:
   Block brand, material, finished bore size, other notes: 1968 Ford 302, 4.03 bore, CnC squared, aligned, torque plate honed
   Crankshaft brand, cast or forged, stroke, journal size: SCAT cast 3.40, 28 oz balanced
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  SCAT 7/16 I-beam 5.400
   Piston brand, material (cast, hypereutectic or forged), dish/dome volume, static CR: Ross pistons, 4.6cc, 9.9:1 SCR
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Clevite rod and main bearings, Durabond cam bearings
   Piston rings brand, size, other notes: Total Seal classic race, 1/16, 1/16. 3/16 Moly top
   Oil Pump, pickup, and drive:  Melling HV, Canton pickup, ARP drive
   Oil pan, windage tray, oil filter adapter:  Cobra cast aluminum T-pan, no tray, no adapter on SBF
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Bullock's Power hydraulic roller, 216 @.050 intake, 223 @ .050 ex, .580 lift 111 LSA
   Lifters brand, type:  Morel standard travel
   Timing chain and timing cover: Cloyes 9-position roller, Ford early SBF aluminum
   Cylinder heads brand, material, port and chamber information:  Trick Flow Twisted Wedge 11R, CnC ported from TFS, 66 cc chamber
   Valve springs: Trick Flow, 160 seat, 400 open
   Rocker arm brand, type (adjustable or non-adj), material, ratio: Comp Cams steel 1.6:1, short Crower poly locks
   Rocker shafts and stands, brand, material:  N/A
   Pushrods brand, type, length:  Custom Smith Brothers 5/16, .116 wall
   Valve covers, brand, type:   Cast aluminum Cobra repop
   Distributor brand, advance curve information:  MSD (dyno distributor, locked at 34 degrees), will run Holley Dual-sync
   Harmonic balancer brand:  Repop Hipo - Scott Drake - 28 oz imbalance
   Water pump brand, type (mechanical or electric):   Tough Stuff aluminum - electric powered on dyno
   Intake manifold brand, material, porting information:  Ford Racing Victor Junior - mild cartridge roll port and plenum cleanup and some port matching (still smaller CSA than port)
   Carburetor(s) brand, type: 780 Holley dyno carb (will get Sniper in car)
   Exhaust manifolds or headers brand, type:  Dyno headers
« Last Edit: August 04, 2025, 06:57:08 AM by My427stang »
Interesting build, but 4.080" bore?  Joe-JDC
Nice Ross
Corrected...a little FE on the brain, it's just a .030 302 block.  Thanks for catching it
6667fan
  • Every Second Counts
What are the particulars on the poly spacer?
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
https://polymerracingproducts.com/products/carb_spacer_4150/
It didn't do much for the big FE, but sure worked on the SBF, both single 4 single planes.
bluef100fe
I’m gonna guess the 347 wanted the extra plenum volume with the victor JR and big FE didn’t..
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
