Author Topic: Who to buy axles from  (Read 6693 times)
c9zx
« on: June 26, 2025, 01:38:36 PM »
I have a 35 spline Strange Detroit Locker center section going into a 1966 Cyclone. Use is hot street on M/T street radials, 4 speed. The prices seem to vary quite a bit. Any and suggestions on who to buy from will be appreciated. Thanks Chuck S.
1969 Eliminator G code
CSX-7031 FIA Cobra
2007 Mustang GT, Whipple
1966 Cyclone GT
cleandan
Re: Who to buy axles from
« Reply #1 on: June 26, 2025, 02:34:30 PM »
hbstang
« Reply #2 on: June 26, 2025, 04:08:42 PM »
is moser compatible with strange splines?
i would buy strange axles.not cheap but super tough.
« Reply #3 on: June 26, 2025, 05:44:06 PM »
Best to check with the manufacturer to see about spline compatibility, I understand that Mark Williams axles have a different spline angle than most others. As for axles themselves, I have had 2 sets of Strange axles in my Fairmont (33 and 35 spline), had 31 spline Mosers in my 85 Mustang, and currently have 31 spline Dutchman axles in my 59. No complaints with any of them. The Moser and Dutchman are considered "streetstrip" versions, and the Strange were drag race only versions.
mike7570
« Reply #4 on: June 26, 2025, 07:16:58 PM »
Rory's correct Mark Williams has its own spline and won't fit other makes of spools or lockers. I was able to have Currie cut MW splines on my axles (something they no longer do) because I had a MW light weight spool. If I ever have a need for new axles or a spool I'll have to stick with MW or change all of it at the same time to another brand.
Jim Comet
« Reply #5 on: June 26, 2025, 07:54:33 PM »
I've had great service and prices from Quick Performance out of Iowa. Jim
cleandan
« Reply #6 on: June 29, 2025, 08:28:25 AM »
Rory, what would make an axle "drag race only" or "street strip"?
I bet this is a designator for a heat treatment or metal difference.
From a physical dimension perspective, I don't see a need for a distinction because it is either machined to fit, or not.
I can see a different metal alloy, and or heat treatment if there is an advantage to that, but that does not change the physical dimensions of the finished axle.
c9zx
« Reply #7 on: June 29, 2025, 02:10:12 PM »
Thanks for the input from everyone.I ended up going with Moser I got great tech support from Jordan as well as "proofing" my order form with me over the phone so I didn't make a mistake. I'd forgotten what a pita it can be ordering axles. Chuck
CSX-7031 FIA Cobra
1966 Cyclone GT
6667fan
  • Every Second Counts
« Reply #8 on: June 29, 2025, 08:56:13 PM »
Did you go with 35s? Not certain those will fit in a stock 9” housing that year. The O.D. of the shafts starts getting to be a concern after 33 spline size shafts in the intermediate housing.
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
« Reply #9 on: June 29, 2025, 10:15:51 PM »
 My understanding is that the difference between a "race" axle, and a street/strip axle is the heat treatment.
c9zx
« Reply #10 on: June 30, 2025, 04:50:25 PM »
^^6& fan the center section is Strange N case, big bearing, 35 spline Detroit Locker. Moser said everything should work. I hope it does. Chuck
CSX-7031 FIA Cobra
1966 Cyclone GT
