Author Topic: 63 ford galaxie axles  (Read 6173 times)
cdale
« on: June 22, 2025, 04:52:48 PM »
Ordering axles for a 63 galaxie stock 9" small bearing. What axle leath I would need going 35 spline. Thanks for any help
Phil Brown
Re: 63 ford galaxie axles
« Reply #1 on: June 23, 2025, 11:15:26 AM »
I would get a hold of who your going to have make your new axle's and ask them what dimensions they need, then go measure your housing
Gregwill16
« Reply #2 on: June 23, 2025, 04:04:38 PM »
Charlie,
I ordered Dutchman 35 spline axles for my 63 a few years ago. They have a form to fill out best I remember. My notes show SR178 axles with 27.875” LH axle and 32.25” RH axle (stock dimensions). There are a few other options such as which studs and spline to meet your requirements.
Jb427
« Reply #3 on: June 23, 2025, 07:17:31 PM »
I may be wrong but I think you need to use large bearing for 35 spline axels I just sold my old diff and built a new one when I changed to 35 spline If you think you need 35 spline axles then you should be using a heavy wall tube hosing as well
« Last Edit: June 23, 2025, 07:28:33 PM by Jb427 »
« Reply #4 on: June 23, 2025, 08:31:26 PM »
If we’re talking about the axle bearing, you can get 35 spline 9” axles with the smaller bearing, Strange made mine.
allrightmike
« Reply #5 on: June 24, 2025, 08:25:38 AM »
   Is it possible to source 31 or 35 spline axles that will fit with small carrier and axle bearings?
« Last Edit: June 24, 2025, 11:40:42 AM by allrightmike »
'60 Starliner 427 4speed.
cdale
« Reply #6 on: June 26, 2025, 04:17:54 PM »
Thanks for all your advice, I called moser order everything with them and yes you can run 35 spline moser has a bearing for small ford 9" housing
