Author Topic: 66 352 block  (Read 4761 times)
driveamerican
66 352 block
« on: June 06, 2025, 09:25:12 AM »
I would like to build 66 352 block for street have not decided if I would go 3.98 or 4.25 stroke how limited are these blocks the place I was going to go for machine work said he wouldn't touch it before he even seen. Are 66 352 blocks that bad he recommended one of his blocks from a 70s pickup for $750 before machine work. I ran.
Re: 66 352 block
« Reply #1 on: June 06, 2025, 08:20:20 PM »
There is nothing wrong with using that block, but since it started at a 4.00" bore you may want to limit the bore size to stock 390 bore size of 4.05".  Sounds like your machinist just wanted to sell you a block.
cleandan
Re: 66 352 block
« Reply #2 on: June 07, 2025, 10:43:04 AM »
Jay said it best...there is nothing wrong with a 1966 352 block from a mechanical standpoint.
If your literal block has issues unique to its condition that is something with that block, not with the 352 block in general.
After sonic checking the cylinders for wall thickness you can then determine, with useful accuracy, how much bore you can deal with on that particular block.
Because the 352 started life at 4.00" bore, and 3.50" stroke, you have some great piston and crankshaft options to choose from that won't cost you huge $$ (relative these days I know)
You may even find some already excellent parts that were removed as someone else made a bigger engine from their already good running engine.
I don't know what you are doing with this engine but one thing I find fun with the 352 is the short stroke.
If you are making a fun cruiser/toy/hot rod that is not really dependent on actual power to win races and such you can cam the heck out of a 352, install good rods, and let it spin to some fun rpm.
It will sound really awesome as you idle around with the radical cam, and it will let you run through the gears with its rpm ability.
Yes, you can make more power with other combinations, but this is just one possible fun result when building a 352...They work awesome in a NASCAR fake because they look the part, and they won't break the bank building it like an honest 427 would.
Concerning the engine builder/machinist...my gut says get far away from that shop specifically because his mind is made up rather than simply working the mechanical/physical problem of machining the block to work properly.
He also does not know FE's, based on what you said, and this can have a detrimental result when building an FE engine.
CaptCobrajet
Re: 66 352 block
« Reply #3 on: June 07, 2025, 12:55:04 PM »
I think I have a set or two of 4.035 bore stroker pistons on the shelf, and also some forged 4.062 bore CP pistons for the 3.50 stroke.
Blair Patrick
driveamerican
Re: 66 352 block
« Reply #4 on: June 08, 2025, 07:16:55 AM »
Thanks for the replies. He might just have to many blocks people can be disappointing. I just hope he really believed what he told me. Thanks again.
