Author Topic: valve drop concern  (Read 3147 times)
valve drop concern
« on: May 16, 2025, 08:16:36 AM »
i have a set of the bbm alu heads with the 2.20 intake valves.my concern is i just watched a video about the LS7 dropping intake valves with under 20,000 miles on them.i have heard the bbm heads uses the same 2.20 valves as the lLS7. any thoughts?
Re: valve drop concern
« Reply #1 on: May 16, 2025, 10:29:20 AM »
Factory valves will be completely different material and construction than aftermarket parts.  Only the diameter is the "same".  Don't worry.
