Author Topic: Late 66/Early 67 428 and C6 From 67 Thunderbird Complete from Air Filter To Pan  (Read 4570 times)
Mr Woodys Garage
Sold, Thanks Guys.
« Last Edit: May 13, 2025, 07:07:59 AM by Mr Woodys Garage »
JacksFordParts
Interested in knowing the date code on this block...
Mr Woodys Garage
The Date Code Is 6H19 Block is C6ME-A A Scratch
Heads And Intake, Heads C6AE 425 G, And Heads C7AE-A
Heads are air pump/smog. with left side tubing and valve in place. air pump is not stuck and turns. same for passenger side heat riser valve.
carb is List-6444 may or may not be original carb, converted to manual choke. not stuck.
plugs all look ok, with exception of cylinder #6, which had some oil on it, but not crusty or sludged up.
had it running briefly in the car before it was removed.
« Last Edit: May 11, 2025, 09:29:25 PM by Mr Woodys Garage »
Mr Woodys Garage
« Last Edit: May 12, 2025, 12:43:58 PM by Mr Woodys Garage »
The Real McCoy
Sent you a private message about the 428. Check your messages. Thanks
63 1/2 Galaxie 500
428 CJ Stroker with 427 2x4 Intake, 427 Long Exhaust Manifolds, Quick Fuel Carbs and TKO 600.
"What gets us into trouble is not what we don't know, it’s what we know for sure that just ain’t so."                            Mark Twain
Sozen
Thanks for letting us know it sold.
