Author Topic: What’s needed to put BBF where 351 was in 70 Falcon?  (Read 6661 times)
6667fan
  • Every Second Counts
« on: May 06, 2025, 08:45:38 AM »
Are the stands the same? Different block plates and insulators?
Thanks
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
gregaba
Re: What’s needed to put BBF where 351 was in 70 Falcon?
« Reply #1 on: May 06, 2025, 09:24:18 AM »
I have done a few conversions using a 429-460.
They basicly bolt in.
I have used both stands from the 351 and the 429 because someone on a forum said they were different and they are not.
Greg
badcatt
« Reply #2 on: May 06, 2025, 05:30:35 PM »
UI have to ask is this a 70, or a 70 1/2? Early 70 are the 67 to 70 body style and the 70 1/2 are the 70 Torino body style.
6667fan
« Reply #3 on: May 28, 2025, 05:00:24 PM »
It’s for a 70-1/2 Falcon. Sounds like stands from the 351 will work.
Thanks
JB
67 Fairlane 500
482 cid 700/617
6667fan
« Reply #4 on: June 07, 2025, 03:05:55 PM »
Owner of car has not been able to get parts to align. Sourced what were supposed to be 429 engine block plates. After the insulators are bolted to the engine plates the insulator does not drop down far enough to align with hole in frame stands. Something not right.
JB
67 Fairlane 500
482 cid 700/617
« Reply #5 on: June 08, 2025, 06:49:39 AM »
Engine mounts have a left and right side.  Has he got them on backwards?  That will keep an FE from dropping down into position in a Mustang.  Ask me how I know this... ;D
6667fan
« Reply #6 on: June 08, 2025, 09:01:09 AM »
Someone else has confirmed stands are the same.
The block plates can’t be switched, one side has three holes, the other four. The owner elected to re-drill one upper hole on each block plate. Surprised that was necessary. Makes me think he has the wrong parts.
Thanks for responses.
JB
67 Fairlane 500
482 cid 700/617
