Author Topic: Rear main seal leak  (Read 3818 times)
pkm123
Rear main seal leak
« on: March 26, 2025, 01:02:53 PM »
Would someone please tell me how best to prevent a rea main seal leak.  I've changed the rear seal once with some improvement and I added a PCV valve, but it's still leaking.  Thanks in advance.
allrightmike
Re: Rear main seal leak
« Reply #1 on: March 26, 2025, 03:59:09 PM »
Find "search" top of page, type rear main leak, lots of info, lots of leaks!
'60 Starliner 427 4speed.
RustyCrankshaft
« Reply #2 on: March 26, 2025, 07:51:36 PM »
Where is it leaking from? The seal itself, the cap? What kind of seal? Couple of things you can try is a different brand seal or maybe one of the one piece seals. Are you using the side seals? If you are I'd probably ditch those. I've had much better luck filling those full of a good quality RTV.
