Author Topic: Johnson Automotive Enterprises 427/482 pump gas, TFS Top end, 642HP/621TQ  (Read 7187 times)
66QBIRD
Dynoed at Johnson Automotive Enterprises WV
642HP@6100 /621TQ@4900
Block: 63 427 Top oiler converted to hydraulic cam
Crank:  4.25 scat steel
Rods:  Molnar
Pistons:  Racetec 10.9
Rings:  malhe 1.5/1.5/3mm gas ported by total seal
Oil pump:  melling 57HV
Balancer: Power Bond SFI
Oil pan: Canton T no windage tray
Camshaft:  Lykins custom hyd roller
Lifters: Morel
Cylinder heads:  TFS middle priced head, out of box
Springs:  PAC
Retainers: Steel 10 degree
Head Gasket: FEL 1020
Rockers: Harland Sharp
Shafts/stands/spacers/studs: Harland Sharp
Smith Bros pushrods
Intake: TFS TW 2x4, power coated silver, Port matched
Carbs: Refurbished 715 holleys
1" open spacers
Distributor:  stock FE,   steel gear and petronix module
Wires:  Accel 8.8
Plugs: NGK v-power
40 degrees advance
Dyno headers 1-7/8
Link to engine build, and for sale.
www.yellowbullet.com/threads/1963-427-482-trickflow-headed-ford-fe-pump-gas-high-vacuum-640-hp
Re: Johnson Automotive Enterprises 427/482 pump gas, TFS Top end, 642HP/621TQ
« Reply #2 on: February 19, 2026, 10:13:42 AM »
Want to follow up on this one.  Jim worked with me on another camshaft iteration for this engine.
I did another hydraulic roller camshaft for it and we ended up with 687 hp @ 6100 rpm and 639 lb-ft of torque.
These were unported TFS heads, with a Tunnel Wedge.  10.9:1, pump gas.
« Last Edit: February 19, 2026, 10:15:26 AM by blykins »
« Reply #3 on: February 19, 2026, 10:21:30 AM »
Very nice!
chilly460
« Reply #4 on: February 20, 2026, 07:19:23 AM »
Picked up 40hp at same rpm with a cam change, was it losing valve control?
This is yet another TFS combo making great power without having to spin it too high, they really are impressive
« Reply #5 on: February 20, 2026, 10:13:27 AM »
Goals changed from first customer to second….
