Author Topic: Is the same finish hone used on all blocks  (Read 3711 times)
dozz302
« on: March 08, 2025, 08:12:58 PM »
Just wondering if the type of finish hone really makes a difference in the ring sealing. When people bring their block to a machine shop to be honed, I'm sure they don't ask "what type of a stone are you using" There are diamond hones, stone hones etc.? What should I ask the machine shop about their honing process if anything at all?
Re: Is the same finish hone used on all blocks
« Reply #1 on: March 08, 2025, 10:13:25 PM »
There are indeed many differences - and many opinions.
Some guys use diamond, others use vitreous stone.  There are advantages to each, and both can be used to make a nice, functional surface.
We can (and probably will as responses to your question come in) use up the whole internet arguing the topic.
The key questions for you are to make sure they at least follow the instructions provided by the ring supplier.  A racer or a pro builder can gain advantages from alternate methods, but the ring supplier is going to at least get you to a safe place.
A good hone is going to use multiple stone grits to arrive at their desired finish.  A coarse initial cut, followed by finer grit cuts establish a plateau for the rings to ride on.
A single grit is not gonna "cut it"...
A torque plate is not mandatory, but it sure as all heck is worth doing.
The cylinder will eventually get "round".  The torque plate gets it closer at the beginning, with quicker break-in, better sealing, and longer life.  Or you can wear out the rings and the cylinder over time to get there.
CaptCobrajet
« Reply #2 on: March 09, 2025, 08:39:28 AM »
Copy what Barry said.  The plateau is important.  A proper hone job is really important.  I have tried and seen tried all kinds of ideas since the mid ‘70s.  For racing, we used to make them super slick back then, almost like a mirror, and always with a plate.  They would seal instantly, and then 35-40 runs later they would slow down and start leaking.  Back then street stuff got a rough hone, and cast iron “quick seaters” on rebuilds.  Sometimes that worked……….for 25-30,000 miles and that would wear out.  Over time, the plateau caught on, and there are many methods and opinions like Barry said.  The general idea is to make it rough to hold oil in the cavities, and then come back and light load it, often with finer grit, and put a slick “top” over the rough underneath.  Slick for the rings to ride on, with oil in the ditches to lube the ring and help make a seal.  Taper top to bottom is critical.  It can wear into a “not so round” hole over time, but taper will wear the piston and the bottom of the ring out, as the ring is constantly being squeezed and expanded as it goes up and down the bore.  A straight and round hole will make more power and live longer, hands down.
The definition of “straight and round” and the method of making the plateau are what makes or breaks it.  If it ain’t round, never put synthetic oil in it until it has many miles on it.  It won’t “wear in”.  If it is round, still don’t put synthetic in it right away.
I have one Stock Eliminator engine running as good as it ever did with about 800 runs on it.  That never used to happen.  Modern ring machining, materials, and surface coatings are light years ahead of old tech.  You can buy $50 rings or $1500 rings and to some extent you get what you pay for.   The plateau also keeps the ring from wearing or burnishing.  Two things that are important in my shop are valve jobs and ring seal.  Those who say “there is no power in a shortblock” are missing something………and it isn’t just power.  They need to run strong and run LONG.
Blair Patrick
MeanGene
« Reply #3 on: March 09, 2025, 04:58:58 PM »
Anyone who thinks the plate doesn't help roundness should look at one that was honed "without" after a few thou miles, when you can see shadows in the crosshatch where the head bolts are. One can go to levels of OCD, like bolting the engine mounts on the block, circulating hot fluid in the block etc. A horsepower here and a horsepower there makes 2 horsepower
