Author Topic: Small intake port head with a " better" combustion chamber and 2.02 intakes?  (Read 17727 times)
Hydraulic roller?
One of each
Solid roller on 469 with Victor
Had roller on 482 with RPM
Both pump gas
Surprisingly similar results
Two engines don't make a trend - but it's a start...
We have seen the same results from 2 TFS combos as well. My 465" engine, and a friends 482".
I'm uncertain what is being done differently to get them to keep pulling, I'm suspecting it's the cam design.
How much duration split are you guys running?  My cams for TFS (and a lot of other FE heads) usually start at about a 10° split and go up from there depending on the rpm and horsepower.  The exhaust port is at about a 68-69% ratio of the intake port.
« Last Edit: March 13, 2025, 01:03:02 PM by blykins »
