FE Technical Forum
Small intake port head with a " better" combustion chamber and 2.02 intakes?
Pages:
3
All
Topic: Small intake port head with a " better" combustion chamber and 2.02 intakes? (Read 17730 times)
Re: Small intake port head with a " better" combustion chamber and 2.02 intakes?
Reply #30 on:
March 13, 2025, 04:43:53 AM »
Hydraulic roller?
Instagram: brentlykinsmotorsports
YouTube: Lykins Motorsports
Reply #31 on:
March 13, 2025, 08:38:46 AM »
One of each
Solid roller on 469 with Victor
Had roller on 482 with RPM
Both pump gas
Surprisingly similar results
Two engines don't make a trend - but it's a start...
Reply #32 on:
March 13, 2025, 11:09:38 AM »
We have seen the same results from 2 TFS combos as well. My 465" engine, and a friends 482".
I'm uncertain what is being done differently to get them to keep pulling, I'm suspecting it's the cam design.
Reply #33 on:
March 13, 2025, 11:17:27 AM »
How much duration split are you guys running? My cams for TFS (and a lot of other FE heads) usually start at about a 10° split and go up from there depending on the rpm and horsepower. The exhaust port is at about a 68-69% ratio of the intake port.
Last Edit: March 13, 2025, 01:03:02 PM by blykins
Pages:
3
All
FE Technical Forum
