Author Topic: 500” Iron High Riser 742 hp/ 674+ tq  (Read 19268 times)
CaptCobrajet
« on: February 22, 2025, 10:44:07 PM »
This was a neat project with some constraints so I thought I would share it.  This engine is going in a real ‘63 Lightweight Galaxie.  The owner wanted to use the C3AE-K early High Riser head to be “period correct”.   Lance Hargis sniffed out a pair of NOS “K” heads.  The K heads are not as good as the F.  The 1970 dated High Riser castings are the best Ford castings, but we needed to use the late ‘63 castings for this.  I hand ported the exhaust side.  For the intakes, I used the prototype port that I made for the Pond High Riser aluminum heads.  I prepped and filled the floors with epoxy, and put some intake seats in with a smaller throat.  The OE throat cut on the K head was too big to support a nice valve job.  The customer had a damaged K head, so we spent some time positioning the cnc program in the K head properly.  Once satisfied with location, we ran the program on the filled NOS heads.  It came out great.  Huge low lift numbers, 325 at .500, and almost 340 at .540.  It went 350 at .600 but we didn’t go there as explained below.
We did not want to cut the ultra rare heads for paired shaft T&D, so I modified the single shaft bolt-on T&D, and limited the lift to a .540 solid roller to keep spring pressures safe, only using the OE mounting.  The block is a ‘63 Top Oiler, 4.278 bore.  The customer had a 4.375 Crower billet crank.  I used one of the last sets of US-made Crower Sportsman 6.700 rods that were made before they stopped doing them.  CP pistons, Total Seal rings.  14:1 static CR.  Repop CV/CU carbs from Carl’s that I went through and prepped like we do for Stock Eliminator.  High Riser “F” 2x4 manifold.  This engine looks externally like a High Riser from the day.
I thought it was neat to see power like this with a bunch of 60+ year old stuff and only a .540 lift camshaft.  There is nothing in this engine that was made in China.  :)
Blair Patrick
475fetoploader
Re: 500” Iron High Riser 742 hp/ 674+ tq
« Reply #1 on: February 23, 2025, 01:07:07 AM »
It’s very neat indeed.  I’m curious what rpm power started to fall off. A real lightweight Galaxy, will this get to make a couple passes?
1967  519 c.i.  TKX 5 speed
bluef100fe
« Reply #2 on: February 23, 2025, 10:18:59 AM »
Awesome to see what’s possible with the old iron… curious how the results would differ with a single plane single 4 intake and a set of F heads. A project I always wanted to build for myself.
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
MeanGene
« Reply #3 on: February 23, 2025, 11:47:35 AM »
That's pretty stout with that little cam- very nice!
CaptCobrajet
« Reply #4 on: February 23, 2025, 03:48:46 PM »
Brady, it made peak power from 6400-6600 but was pretty broad over the top.  When we were looking for peak, I ran it past 7000 and it wasn’t falling off much.  I think a person would want to shift it at 7300.
Cody, same result head-wise using an F head, because the port would be the same with the floor filled and the program run through it.  The single plane 1x4 intake would be interesting if only there was one.  Dove made a few but they need a half gallon of Z-spar in the floor of the plenum and they are hard to find.
From what I understand, they plan to run the car some.  It has good brakes and Cal Tracs, etc.
Gene, we did a 511 several years ago with a .700 lift cam, Pond heads with some more work, and still the F manifold with two 850-ish carbs that made 796 hp and over 700 tq.  We had the paired shaft T&D on that one.  It surprises me how well that High Riser 2x4 intake will support pretty big power.
Blair Patrick
« Reply #5 on: February 23, 2025, 07:50:29 PM »
Dumb nice work. I know you put a lot of work into the heads but 740 HP with that little cam is amazing. Pretty big bore on that stock block were they getting thin in some places.
MeanGene
« Reply #6 on: February 23, 2025, 09:21:11 PM »
Velocity and a well-matched combination is a wonderful thing!
« Reply #7 on: February 24, 2025, 10:16:23 AM »
That's a sweet running piece of factory iron !!
MeanGene
« Reply #8 on: February 24, 2025, 10:52:29 AM »
Starting to get that itch to do something with my PIE heads  :o
« Reply #9 on: February 25, 2025, 12:33:57 AM »
 im waiting on my irs refund so i can go see mr blair!  im taking my heads and intake to him and also see what all he might sell me while im there. that fe-irs money is burning a hole in my pocket and i aint even got it yet!
« Reply #10 on: February 25, 2025, 09:38:32 AM »
Didn't Dove make some 2x4 Tunnel wedge HR style Intakes ? That'd be sweet if Pond could knock a few of those out
428kidd
« Reply #11 on: March 26, 2025, 07:48:19 AM »
Yes dove made some TW style intakes for there PIE heads. Very hard intake to find today. Usually missing from the heads.
MRHP
« Reply #12 on: April 12, 2025, 12:32:37 PM »
Might get a couple hits on it this season God willing and the creek don't rise...lol
MRHP
« Reply #13 on: April 12, 2025, 12:37:42 PM »
Current status
« Reply #14 on: April 12, 2025, 02:12:07 PM »
Very nice
