Author Topic: ARP rocker stud torque  (Read 3866 times)
allrightmike
« on: February 08, 2025, 09:39:10 AM »
  Despite my meticulous record keeping methods (huh?) I cannot find the data slip for my ARP rocker mounting studs. Not wanting to guess at it, someone please chime in with the torque spec for said studs. Thanks.
DuckRyder
Robert
allrightmike
Re: ARP rocker stud torque
« Reply #2 on: February 08, 2025, 01:10:52 PM »
Yup, thanks.
6667fan
  • Every Second Counts
« Reply #3 on: February 10, 2025, 09:48:29 AM »
I have always done them to 50 lbs. That is higher than the pdf indicates.
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
« Reply #4 on: February 10, 2025, 10:26:00 AM »
I'm usually a 40-45 lb-ft kinda guy.
pbf777
« Reply #5 on: February 10, 2025, 12:29:59 PM »
    Yep, from the installation instruction sheet:  "Once the rocker shaft is pulled down into place, tighten the nuts to 35 ft-lbs if using ARP assembly lubricant or 40-45 ft-lbs if using engine oil".
    I'd recommend pretty much sticking to this recommendation.   :)
    Scott.
allrightmike
« Reply #6 on: February 13, 2025, 10:21:25 AM »
10-4 that.
