Author Topic: FLYWHEEL BOLT PATTERN  (Read 7501 times)
allrightmike
« on: January 18, 2025, 03:15:21 PM »
Do any of you have FE flywheel bolt pattern dimensions either in XY straight line charting or in degrees ( I believe all holes are on a common BC dimension). I am making a flywheel balancing mandrel and do not wish to transfer locations from a flywheel, might end up with a bad copy of a poor original!
'60 Starliner 427 4speed.
allrightmike
Re: FLYWHEEL BOLT PATTERN
« Reply #1 on: January 19, 2025, 01:58:13 PM »
Answering my own question. Charted with the rotary table on the mill.. If the photo will come through here it is.
« Reply #2 on: January 19, 2025, 05:21:35 PM »
A BIG THANK YOU!!! :)
Dr Mabuse
« Reply #3 on: January 19, 2025, 08:27:39 PM »
One hole offset, so it can only go on one way?
allrightmike
« Reply #4 on: January 19, 2025, 08:31:52 PM »
You are correct sir.
Urgefor
« Reply #5 on: January 19, 2025, 11:42:02 PM »
I would assume that was in relation to the externally balanced 428s of the day.  That makes me wonder if all FEs were like that from day one?
mike7570
« Reply #6 on: January 19, 2025, 11:44:13 PM »
When I find it, I use permanent marker on the crank and flexplate to make it simple to R&R.
allrightmike
« Reply #7 on: January 20, 2025, 09:21:18 AM »
All FEs have the same flywheel bolt pattern whether internal or external balanced.
galaxiex
« Reply #8 on: January 20, 2025, 02:14:26 PM »
Every Ford engine that I have seen, small medium or big block,
Has one offset hole on the crank flange.
Regardless of internal or external balance.
« Reply #9 on: January 20, 2025, 03:30:32 PM »
It is funny, there really is no reason to have them like that from the early internally balanced FEs...but you are correct, it makes the externally balanced ones much easier to put where they are supposed to be!
galaxiex
« Reply #10 on: January 20, 2025, 04:05:54 PM »
Actually it’s not just Ford.
GM and Mopar also offset one hole as well.
I imagine the same applies to the imports too.
« Reply #11 on: January 20, 2025, 08:51:47 PM »
There's a reason most everybody does the offset hole.  You want your super expensive engine machining line to handle an external balance version.  Engines tend to grow over time, and external balance is sometimes the only way to economically get that longer stroke.
