FE Technical Forum
new carb wont idle
Topic: new carb wont idle (Read 3475 times)
hbstang
Sr. Member
new carb wont idle
January 07, 2025, 04:21:55 PM »
bought a 3310-1 that was new,ran good for a year or so,but now wont idle,like a giant vacuum leak.i have looked over the carb and install and found nothing wrong.could it be somthing in the main body?
Jim Comet
Sr. Member
Re: new carb wont idle
Reply #1 on:
January 07, 2025, 08:13:00 PM »
If it has sat for a long period, I have seen gasket shrinkage cause issues. I would pull the bowls and blocks and look for anything obvious. Cheapest and easiest place to start along with fresh gas. Jim
Reply #2 on:
January 07, 2025, 11:50:29 PM »
i run no ethanol gas in mine or the carb gets sticky and gums up with the 10 percent ethanol,never had a problem using good 93 no ethanol
1966 comet caliente 428 4 speed owned since 1983 1973 f250 ranger xlt 360 4 speed papaw bought new
Reply #3 on:
January 08, 2025, 03:16:59 PM »
Maybe check that the intake manifold carb base covers/supports the PCV cavity completely and that the intake manifold matches that area for gasket support, I had a 3310-4 that had a bigger PCV cavity than what the intake manifold carb had and caused a vacuum leak after a couple days of running it because there was no gasket support in that area , ended up installing a 1/8th plate carb adapter from Edelbrock that supported the gasket at the carbs PCV cavity despite the mis pad match between the intake carb pad to carb PCV vacuum cavity
Last Edit: January 08, 2025, 03:20:05 PM by e philpott
FE Technical Forum
new carb wont idle
