Author Topic: plug wires  (Read 17421 times)
390owner
plug wires
« on: December 08, 2024, 09:24:39 AM »
I had a miss with my 390 pulling a hill. So I opened the hood after dark with it idling and had blue fire around the 4 front plug wires One of them was arcing  from the plug to the distributor. So I bought a new set of ford racing wires. They are doing the same thing. I put a small amount of grease inside the wire boots. What am I missing?
gregb
Re: plug wires
« Reply #1 on: December 08, 2024, 11:04:49 AM »
I'd change the cap too.....how old are the plugs?
390owner
Re: plug wires
« Reply #2 on: December 08, 2024, 07:27:11 PM »
I have an hei distributor and the plugs arent that old maybe 5000 miles
TJ
Re: plug wires
« Reply #3 on: December 09, 2024, 08:56:39 AM »
Before spending anymore money, look at the plugs...even though they're relatively new.  Also, clean the contacts inside the cap if it hasn't been done in a year or more.  At the least, pull it off and look inside.
Also, even though your wires are new, they may have been damaged if you pulled them off the plugs by hand.  Some wires can tolerate being pulled off the plug by grabbing the boot.  Some wires break apart inside if you don't use plug wire pullers.
Electricity can be like water.  If it can't go where it's supposed to go, it goes someplace else.
« Last Edit: December 09, 2024, 09:07:35 AM by TJ »
GerryP
Re: plug wires
« Reply #4 on: December 09, 2024, 12:08:45 PM »
The corona around the spark plugs is just physics.  Under the right atmospheric conditions and, of course, darkness, you will see this corona even with new wires.  The arcing is something that needs to be addressed.  There is resistance higher than the intended path can handle.  It could be a spark plug gap too wide, a fouled plug, a carbon tracked cap, the wire terminal not seated into the cap and all that.
Thumperbird
Re: plug wires
« Reply #5 on: December 09, 2024, 12:22:53 PM »
Probably not it but a quick check for a good engine ground?
MrRupp
Re: plug wires
« Reply #6 on: December 09, 2024, 05:34:16 PM »
I was always taught that electricity is lazy, and it will find they easiest path. Sound like to me is you have a carbon track in the distributor cap. Just a guess.
390owner
Re: plug wires
« Reply #7 on: December 10, 2024, 07:28:11 AM »
Thanks for all the replies. I will check the cap and the plugs
Re: plug wires
« Reply #8 on: December 10, 2024, 08:28:19 AM »
i went through the same thing.i replaced everything,changed the plugs last and thats what it was!
390owner
Re: plug wires
« Reply #9 on: December 10, 2024, 06:43:20 PM »
The rotor had a little bit of arcing marks on the inside tabs and the rotor end looks a little worn. May just replace the plugs and the rotor and  cap
390owner
Re: plug wires
« Reply #10 on: December 11, 2024, 06:36:24 PM »
Ordered a new cap and rotor bug. What plugs are you guys using. I have autolite 45 now
gregb
Re: plug wires
« Reply #11 on: December 14, 2024, 10:16:53 AM »
Autolite 45 is what I use.....
390owner
Re: plug wires
« Reply #12 on: December 27, 2024, 07:52:27 PM »
New cap rotor, plug wires and it is still arcing Plugs are next
Faron
Re: plug wires
« Reply #13 on: December 29, 2024, 02:23:28 AM »
Plugs should of been First , given the Ifo provided , I also disagree with All wires will have the Plasma display , if the do they are leaking energy , and yes electricity is lazy easiest path to ground , and speaking of GROUNDS , to many combos with poor Engine Grounding , when in doubt add another !
390owner
Re: plug wires
« Reply #14 on: December 30, 2024, 07:41:28 AM »
Over the years on my trucks I have owned every time this happened it was the wires. That is why I changed them first. The plugs are on order so the worst thing is I have a new rotor, cap, wires, and plugs. I enjoy asking questions here to get your opinion. Sometimes you guys are right on the  problem other times your not. Thanks for all the responses
